DV install question
Old Dec 17, 2007 | 03:16 PM
feerocknok's Avatar
Default DV install question
The outlets on my stock DV fit inside the ones on my Forge 007... How am I supposed to get it to go back into the stockhoses?
And do I need to tee in the nippple on the top of the valve to another vacuum line?
Old Dec 17, 2007 | 03:32 PM
McGovs2.7TB5's Avatar
Default RE: DV install question
I did mine yesterday (Forge007 as well) and when I finally got the 1 time clamps off the Forge slid right into the stock hoses no problem. If you have trouble the DIY info I used said to spread a small amount ofoil to lube the DV inlets.as far as a tee in the vac line not too sure what your askin there cause the stock DV had 3 hoses and I hooked upthe Forge the same way the stock was.
Old Dec 17, 2007 | 04:08 PM
feerocknok's Avatar
[sm=smiley5.gif]
Pulled off the wrong part...
The diverter valve looks a little trickier to get to than what I pulled...
Old Dec 17, 2007 | 04:22 PM
here's the DIY I used. Hope it helps. http://awe-tuning.com/pages/info/awe...dow.cfm?FAQ=30
Old Dec 17, 2007 | 04:34 PM
what?'s Avatar
To get the 1 time clamp off, disconnect the other hoses first...And then just muscle that bastard off.
Old Dec 17, 2007 | 05:17 PM
veloracer's Avatar
The one-time clamps are a PITA, but once you get them off, it's real easy to put everything back in place.
Old Dec 17, 2007 | 05:54 PM
AUDI05's Avatar
Hey guys I tried all day to get the one time clamps off so I could install my forge004, and no luck. Im ready to just return the forge004.. I can't get the clamps off, and Im worried what the BOV would do to my warrentee.
Old Dec 17, 2007 | 06:13 PM
just stick with it audi05, they were a major pita for me but you'll feelgood aboutitwhen you're done.
Old Dec 17, 2007 | 06:16 PM
Papachristou's Avatar
i had hell getting those one time clamps off.. there is a trick to it, you need a L shaped pick to slide in there and bust them off but there is little room by the DV, i found that a dremel tool solved my problems [:@]
for the top piece, i just cut it off at the nipple and zip tied it on to my R1... no problems
Old Dec 17, 2007 | 06:34 PM
feerocknok's Avatar
Hacksaw blade.
Jacked the car up a foot, set my head up and sawed. Took awhile so I just got in a comfy position.
