Which DV should I get?
I'm looking at getting a REVO flash, and understand that I should upgrade the DV as well. My question is, which DV should I get? The ones that I've seen mentioned are:
710n (TT) Forge 007 APR R1 Stratmosphere Hyperboost Evo Your input is greatly appreciated. Car info in sig. Thanks! |
RE: Which DV should I get?
if revo is all your planning in the future than a 710n will be fine. if your gona upgrade the turbo, go with any of the others. there all practically the same, just make sure you get one with interchangable springs
I think i read that you don't have to service apr r1s. Which is why im getting it, lol.
Do the R1s have springs? i dont think so.. |
nm R1's moo.. get forge
again, this is coming from a newb: why do you need a DV? do you need to buy a new DV when you chip your car?
and which chips would you all recommend? |
A simple search does wonders.
this one is even a sticky at the top of the page, not sure how you could miss it. https://www.audiforums.com/m_531160/tm.htm |
| All times are GMT -4. The time now is 05:46 AM. |
