easy methods
Old Sep 24, 2006 | 07:24 AM
mattn2005's Avatar
Default easy methods
IS there any thing I can buy fluid wise to keep my car running good? as in to put in the gas tank (i know techeron makes something), or any other any additives? to clean out everything or increase performance
Any thoughts WELCOME Bros
Old Sep 24, 2006 | 07:43 AM
BadLuckAudi's Avatar
Default RE: easy methods
I dont think many of those addatives really do as good a jobas they claim, i say just run premium fuel all the time and youll be ok for the most part
Old Sep 24, 2006 | 07:48 AM
joe4123's Avatar
Member
some red line fuel injection cleaner every once in a while and your good to go
Old Sep 24, 2006 | 11:45 AM
david9999's Avatar
Techron and REDLINE are pretty good, However if you buy branded gasoline (Texaco or Shell) you will get high quality additives.
If youwant to keep your car running well over the long run, don't forget the other fluids in your car.
DOT 4 brake fluid - change every two years. It is hygroscopic and if not changed regularly, you will lose braking efficiency and your calipers may rust.
Power steering fluid - Pentosin 11S. Get a turkey baster suck out the reservoir and put fresh fluid in.
Change the center, front and read differential gear oil with new synthetic every couple of yours. I do mine every 60K
Transmission fluid/gear oil
Check the battery and top up with distilled water ( twice a year).
Old Sep 24, 2006 | 01:33 PM
bluovalguy's Avatar
Just use quality products for regular maintenance and good gas. If you do that you shouldnt need extra stuff.
Old Sep 24, 2006 | 01:45 PM
chaos92287's Avatar
dont waste the money on additives. premium fuel from shell or chevron and scheduled maintainence are all you need to keep the car running great for a long time
Old Sep 24, 2006 | 02:25 PM
bottled leaf's Avatar
I just put in Shell Premium, I was previously using Exxon premium, and it has really cleaned my system. Definitely get Shell gas.
nlinesk8s
Jun 21, 2015 03:39 PM
Trancy201208
Aug 13, 2012 03:12 AM
Lmal355
Apr 25, 2011 07:36 AM
TeeterTawter
Jul 13, 2006 01:07 AM
exceldetail
Dec 14, 2004 04:51 PM
