ebay vag?
Old Sep 6, 2006 | 08:14 PM
sheek's Avatar
Default ebay vag?
http://cgi.ebay.ca/USB-KKL-Vag-Com-C...QQcmdZViewItem
Any feedback on these ebay vagcom tools? I'd definatly rather pay 20$ instead of the ross tech 200$ if it'll work the same. I've been around long enough to notice everyone here hates ebay products for their audis and i understand why but this isn't a car part, just a tool I need. Any info or opinions would be appreciated.
Old Sep 6, 2006 | 10:00 PM
SlowWagon08's Avatar
Default RE: ebay vag?
if you just want to do the vag mod then that will be fine. you might have to tinker with the drivers to get your laptop to see it. if thats all you need it for then it's good enough.
Old Sep 6, 2006 | 10:14 PM
sheek's Avatar
well I was going to try the real time wheel speed sensor monitoring. . .I'm guessing the ebay software only gives codes without other functions?
Old Sep 6, 2006 | 10:25 PM
chuckievi's Avatar
My vag is off of e-bay and it worked for a grand total of 4 months before it died. Next pay check I am just going to buy a real one from Rosstech and do it right. Yeah its expensive, but at least i know it'll work when i want to read a code!
Old Sep 7, 2006 | 12:10 AM
david9999's Avatar
The ebay versions are cheap, and will work with some old versions of the Rosstech software in a limited fashion. It will probably work for reading codes, but not guaranteed to work.
besides, the
Ross tech doesn't cost 200 dollars. I figure it has saved me a grand. Plus, when/if I sell my Audi, I can sell the RossTech version on ebay for 150 and recoup much of the original cost.
Old Sep 7, 2006 | 01:30 AM
danx99's Avatar
i have a vag cable from eBay and it works just fine. i'm using the older version of Ross-Tech and if you know what to look for you can get the full version for a good price
Old Sep 7, 2006 | 02:18 PM
grizzles's Avatar
I just bought that same exact cable off ebay and it seems to work fine. Here is a good walk through on how to get it to work and change some convience-type codes: Ebay VAG-COM Cable Walkthrough
I am brand new to the Audi world and VAG-COM so I am not real sure whether the real-time wheel speed sensor monitoring will work with this cable. One important thing to point out is that you will definitely have to get some better software than the free version (wouldn't let me change Module 9 codes) and this type of cable apparently won't work with the newer versions of VAG-COM.
Old Sep 7, 2006 | 04:09 PM
Jovian's Avatar
ORIGINAL: grizzles
Thanks for that link it answered a lot of my questions =)
Old Sep 7, 2006 | 05:21 PM
sheek's Avatar
How would one obtain older vag com software to use with this cable?
Old Sep 7, 2006 | 05:30 PM
grizzles's Avatar
ORIGINAL: sheek
Direct Download Link (from ross-tech.net)
But like I said earlier, some stuff doesn't work. I was able to do the windows up/down on the key fob and turn off the seatbelt chime yet I was unable to turn off the ambers on my halogen lights. Others say they have been able to do it with bi-xenons but it seems there is a shareware issue involved. As far as logging, etc. I haven't done any of that, I just got my car and haven't had a need......yet. Good Luck.
h4x0r
Aug 9, 2022 10:50 AM
EriCal
Jan 20, 2010 12:38 AM
darm87
Nov 25, 2008 04:14 PM
Jeff
Feb 17, 2006 09:08 PM
