ECU
Old Dec 5, 2007 | 06:58 PM
tooxtreme8813's Avatar
Default ECU
i bought an ECU from a 99.5 1.8T ECU #8D0 907 559 C will this work in my 99? my ecu is 8D0 907 557 P. i am the same year as the person who i bought it from...i'm 99 quattro automatic aeb ndbw and he is 99.5 quattro automatic aeb ndbw
Old Dec 5, 2007 | 07:42 PM
Default RE: ECU
anyone??
Old Dec 5, 2007 | 08:05 PM
ocadam's Avatar
Default RE: ECU
Im pretty sure the ECU numbers have to be the same.
Old Dec 5, 2007 | 08:09 PM
Bogie's Avatar
Default RE: ECU
they may be different if one car has/doesn't have electronic stability program. I know that was an option on the 2000 ATW engine ECUs. Call a junk yard tomorrow to ask them if they are compatible. The dealer will most likely tell you no, even if they are. they told me the ecu from a 1.8T passat wouldn't work in my car but it did. Also there is no immobilizer for our year cars, so if the dealer tells you that too, don't buy it. put it in and see if it will work. you shouldn't hurt anything by trying it.
Old Dec 5, 2007 | 08:17 PM
Default RE: ECU
ORIGINAL: Bogie
its the same year same engine its just that the 99."5" has the updated body features etc. no 99 had esp
Old Dec 5, 2007 | 08:26 PM
Lazer Viking's Avatar
Default RE: ECU
i have never heard of a 557c
even the passat's are 557p
Old Dec 5, 2007 | 08:28 PM
Default RE: ECU
ORIGINAL: Lazer Viking
its a 559 C
Old Dec 5, 2007 | 08:32 PM
Bogie's Avatar
Default RE: ECU
Do you actually have it with you now? Did it work in the 99.5 car it wasused in last? If so then justtry it. If you need help on howto disconnect yours and put in the other one, justlet me know and i'lll walku right through it.
Old Dec 5, 2007 | 08:35 PM
Default RE: ECU
ORIGINAL: Bogie
yes it was in a 99.5 car and it worked. I have the ecu on me but i dont have my car its at our shop. i was adjusting some things on my BT kit and took the car out for a drive and the ECU died. I bought a used one for 90 shipped from the saem year car as mine i need to know if its compatible so i can send it to unitronic to get re-chipped. he said it was and it worked fine on his car and its the same as mine but im just double checking
Old Dec 5, 2007 | 08:40 PM
Bogie's Avatar
Default RE: ECU
How did yours die?
