ECU Code p1136?
Old Nov 22, 2004 | 04:04 PM
99BlackA4's Avatar
Default ECU Code p1136?
Been gone for a while fellas, finally got done with install in my accord and car audio finals. Well now here's my problem:
I get a p1136 code when I pull the code, Does anyone know where I can find description of the problem based on that code.
TIA,
Jose
Old Nov 22, 2004 | 04:51 PM
Jestnomen's Avatar
6th Gear
Default RE: ECU Code p1136?
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-00
Probably a MAF related issue or a bad vacuum line. Replace the vacuum lines or check for leaks, then clear the code. If it comes back theck your MAF.
Old Nov 22, 2004 | 07:28 PM
99BlackA4's Avatar
Thanks, will look into it..
Old Nov 22, 2004 | 07:38 PM
Jestnomen's Avatar
6th Gear
what are you using to read the codes?
D3G
Jan 14, 2011 10:44 AM
netoLopez
Nov 11, 2010 02:49 PM
rafa_207
Feb 6, 2008 04:37 PM
widlcats
May 29, 2007 11:01 PM
tonym
Jun 14, 2006 03:49 AM
