ecu? obd codes 301 302 help!!! asap
Old Mar 6, 2007 | 11:22 AM
breeze.12's Avatar
Default ecu? obd codes 301 302 help!!! asap
I have a 2000 a4 quattro 1.8T 115 k mi. runs very rough at start up when cold but then smoothes out as it gets warm. yet if I rev it a little,or put some power to ityou can here it miss&coughs. I have changed all the plugs and coil packs( napa $25 ea.), but still the same codes.and have also pulled the plug boots,and can hear a steady arc even when the car is missfiring. in these post it sounded like a icm or power amp, yet this car does not have either. all the plugs are sooty & black. Thanks for sharing your wisdom and knowledge. these forums are awesome. ps: car is undriveable due to this I believe they call it limp modeplease help asap. thanks again
Old Mar 6, 2007 | 11:39 AM
CRAZYHAWK's Avatar
Default RE: ecu? obd codes 301 302 help!!! asap
Sounds like you're runing rich without a rich code. Change your
air filter. You might be using a spark plug that is too cold. NGK heat
range should be 6.
Old Mar 6, 2007 | 11:54 AM
breeze.12's Avatar
thanks, has new air filter, also I believe a code 1238 wa previously retrived but has never come back. ???? also,with the new plugs it runs identical as with the original platinums.
Old Mar 6, 2007 | 12:35 PM
oh1a4's Avatar
1238 cyl 2 fuel inj circ open circ
302 sometimes indicates icm (if you are positive its not coil pack related)
you should be running the latest revision audi coilpack and double platinum plugs, as already advised use a 6 (PFR6Q)this isnt the place to save money.
if you keep getting 302 after putting good coilpacks in, then you may want to check the icm
Old Mar 6, 2007 | 06:21 PM
CRAZYHAWK's Avatar
oh1a4, He doesn't have a ICM.
Old Mar 6, 2007 | 11:21 PM
breeze.12's Avatar
Im going to swap more new coil packs tommorow, a new po304 code showed up, wondering if one of the new coil packs were faulty.
mabtheone
Apr 12, 2011 05:09 AM
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
LeAudi19
May 7, 2008 01:53 AM
Gumby11
Jan 17, 2008 07:02 PM
