Engine Codes!!!
Old Nov 27, 2006 | 08:40 AM
CRAZYHAWK's Avatar
Default RE: Engine Codes!!!
Ask the GIAC place that flashed it?
Old Nov 27, 2006 | 09:08 AM
techbod's Avatar
my apols there P1556 is indeed the turbo must have been looking at something else[8D] but old crazy sussed it
Old Nov 27, 2006 | 12:30 PM
smokeU's Avatar
you may be overboosting. i had that problem. try disconnecting the battery for a while and then reconnecting. then give the car time to adapt. dont try pushing it or the ECu will throw the overboost code. thats what i did and after two weeks of babying it my car was fine. do you have cel?
Old Nov 27, 2006 | 01:19 PM
techbod's Avatar
it might be worth testing the wastegate valve if you cant find any leaks
[IMG]local://upfiles/12092/9E85BC6FF68246709203813D35708199.jpg[/IMG]
Old Nov 27, 2006 | 01:42 PM
NuYorka103185's Avatar
well I am not good with messin with cars so I regret to inform you guys that I am taking it to the stealership today to correct whatever is wrong.[:'(] Anyway thanksfor all the hel and I'll let you guys know the cause of the problem when I findot what it is.
Old Nov 28, 2006 | 03:40 PM
the culprit the air pump according to AUDI. The airpump and o2 sensors came up when he cleared the code only the airpump came back. he says $420 for the part + install on top of the $120 for doagnosis of the problem. Is the airpump worth changing, he says the stock one may be fine but it is throwing a cade and will need additional testing. All I heard was $$$$$$$$$$$$$$ CHA-CHING$$$$$$$$$$$$ BEND OVER $$$$$$$$$$$$$$ Any opinions ona possible alternative??
Old Nov 28, 2006 | 03:46 PM
acetrebo's Avatar
ORIGINAL: NuYorka103185
Bring your own KY to save a few bucks?
Or replace it yourself.
Old Nov 28, 2006 | 03:56 PM
  #18
techbod's Avatar
change the fuse and relay to be found under the hood
[IMG]local://upfiles/12092/61C0AAAE865745FDB454637757DFF5EF.jpg[/IMG]
[IMG]local://upfiles/12092/31516FAC68B14ECCA1101E3F1639831F.jpg[/IMG]
Old Nov 28, 2006 | 04:30 PM
  #19
thnx I'll try that
Old Nov 30, 2006 | 08:42 PM
  #20
where under the hood?
vtraudt
Oct 31, 2010 10:11 PM
Lollygagger
Apr 9, 2010 09:43 PM
speedfreak_josh
Sep 21, 2007 08:23 PM
A6fan
Nov 10, 2006 03:59 PM
