Engine coolant
What do you guys use for your engine coolant? Is it safe to put an additive from Royal Purple that lowers the temperature of the coolant. Anybody using this additive?
RE: Engine coolant
I would stay away from additives in general. 50/50 G12 engine coolant and distilled water is the only thing you should really have in there.
RE: Engine coolant
You can also use Yellow that replaces any antifreeze. Global Extended Life Antifreeze.
RE: Engine coolant
I wouln't trust anything other than pink G12 in my coolant system. It's only 20 bucks a gallon and lasts for years. A small investment if you ask me.
RE: Engine coolant
The money saved isn't worth the risk. Given the cost of replacing the parts vs the potential saving of a few bucks on antifreeze, I would stay with G12.
RE: Engine coolant
Where can I find G12 coolant?
RE: Engine coolant
Dealer or most any Euro parts house.
RE: Engine coolant
why is it soooo much better?
RE: Engine coolant
There are many different coolents with different chemical properties. Audi's come with Pentosin G12, therefor that's what I use. I see no reason to risk my cars cooling system to save 41 cents a month by using the cheap stuff.
RE: Engine coolant
Sounds good. thanks. I never knew that before. sorry if it sounded like I was being a jerrk about it. I was just curious as to why G12 was the best for AUDI. thanks again Jest
| All times are GMT -4. The time now is 08:16 PM. |
