Engine Fault Code
Old Oct 30, 2006 | 04:47 PM
JMart's Avatar
Default Engine Fault Code
I had someone with a VAG-COM tool help me find out why my check engine light was on but he did not have the decoder to find out what the fault code meant. Does anyone have access to one? I have an '02, A4, 1.8, B6/B7 and this is the fault code instructions the VAG-COM tool gave:
Address 01: Engine
Part No SW: 8E0 909 518 G HW: 8E0 909 018
Component: 1.8L R4/5VT G 0002
Coding: 0016581
Shop #: WSC 63351
1 Fault Found:
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 001 - Upper Limit Exceeded - MIL ON
Readiness: 0000 0000
Help please!
Old Oct 30, 2006 | 05:25 PM
onepoint8tee's Avatar
Default RE: Engine Fault Code
Your car is a B6, not a b6/b7. There is no decoder for vag com that im aware of. It will give you the code then you have to find out what it means. There is a write up somewhere about what all the fault codes mean.. Try searching "17544 - Fuel Trim: Bank 1 (Add): System too Lean" in any search engine like yahoo, or the search here. Im guessing your MAF is bad. I had that code when my MAF was bad.. But try to think of other things that can make you run lean like fuel restriction, 02 sensor, etc.
Old Oct 30, 2006 | 05:27 PM
techbod's Avatar
air leak by my data it could be a vacuum pipe off or split
Old Oct 30, 2006 | 05:40 PM
chaos92287's Avatar
ORIGINAL: avant80@2.6
but then wouldn't he be running rich not lean?
Old Oct 30, 2006 | 06:14 PM
techbod's Avatar
too much fuel would be running rich
too much air would make it run lean
Old Oct 30, 2006 | 06:18 PM
techbod's Avatar
[IMG]local://upfiles/12092/3977847FD51F405F904BBB724C2DE1AA.jpg[/IMG]
Old Oct 30, 2006 | 06:28 PM
chaos92287's Avatar
o i just figured that if a hose was split then that means air is leaking out and there is more fuel in the a/f ratio. but this is why your dave and im jus chaos. always trust dave's word over mine
Old Oct 30, 2006 | 07:11 PM
ORIGINAL: chaos92287
except for when he gives his monthly "goodbye to audifourms.com" message... Never trust that statement! He'll always come back with a screen shot that conflicts with my troubleshooting suggestions.
Old Oct 30, 2006 | 07:23 PM
techbod's Avatar
6 monthly lol screen shots are nothing personal to your troubleshooting suggestions
Old Oct 30, 2006 | 07:28 PM
our troubleshooting suggestions mesh well. One of us has got to be right.
