engine light
I have a 99 a4 2.8. The engine light came on and I pulled 4 codes. I would appreciate any help or explanation. The codes are p0332, p0455, p0118, p1138 thanks.
RE: engine light
P0118 coolant temp sensor or wire short to ground
P0332 insecure/poor wiring connectionknock sensor bank 2 [hr] P1138 long term fuel trim, idling bank 2 ( probably caused by the other problems ). edit: P0455 large leak detected EVAP system |
RE: engine light
So I'm possibly looking at an electrical/wiringproblem. I'll check wiring around coolant reservoir. What else should I look for.
RE: engine light
the last code is the most important ( large air leak ) and probably responsible for the rest so check all the pipes to the intake and from the EVAP purge valve
RE: engine light
thanks for the info. I'll check all lines, hopefully I'll find something.
RE: engine light
where is the evap purge valve located?
RE: engine light
[IMG]local://upfiles/12092/3DFF27ACAF824D94B77ED6C6C28B773B.jpg[/IMG] |
RE: engine light
P0455 > Gas cap loose
RE: engine light
i recently had the fuel trim code after an inspection. i repaired 2 vacuum hoses that were cracked and the problem was solved. look over all hoses for cracks, loose fit etc.
