Engine Management System...
Old Jan 10, 2005 | 05:36 PM
Walls's Avatar
Default Engine Management System...
Hey guys,
My first time on this....
I've got an A4 2001 2.0... bought 3 months ago... love it to bits but..
The Engine Management Sytem light keeps coming on. Ever since I bought it its been on and off about 10 times... the strange thing is the car runs fine..
I've taken it to a mechanic and they gave me a list of codes and said if they really were faults the car wouldn't run... they just reset the system, and sent me packing...
The light just came on again tonight...
Anyone have any idea what it could be???
Codes are -18043, 17698, 17545, 17072, 17645, 17647, 17648, 17646, 18010
Much appreciated
Walls
Old Jan 10, 2005 | 09:37 PM
Walls's Avatar
Default RE: Engine Management System...
Am I the only one with an engine management light problem?
Old Jan 10, 2005 | 09:43 PM
AML 225's Avatar
Not sure what to tell you exactly, I had some problems with warning lights and while my car runned fine there was problem with my Cat. Converter and Mass Air Intake. If I were you I'd take it to an Audi dealership and see what they say....
Old Jan 10, 2005 | 09:44 PM
AML 225's Avatar
Forgot to mention that I was told the lights were no real problem either, luckily I took it to the dealership and the cat. converter was just barely still under warranty!
Old Jan 10, 2005 | 09:53 PM
Walls's Avatar
Thanks... I'll get it checked out asap..
Old Jan 10, 2005 | 10:00 PM
Walls's Avatar
By the way.. the lights seams to come on when I over rev the engine, or for no reason at all... did that happen to you? The mechanic I took it to is quite reputable... he said it might have had some engine work done (what ever that means????).... I'm worried I bought a dud?
Old Jan 10, 2005 | 10:47 PM
Jestnomen's Avatar
6th Gear
17698- Coolant Temp Sensor (G83) Signal Too Small
002 Lower Limit Exceeded- Intermittent <---------speaks for itself
17545 - Long Term Fuel Trim Add.Fuel (Bank 1) System too Rich
35-00 - - <----------Check O2 sensor, Check FPR, vacuum lines, check for exhaust leak
| 17645 | P1237 | Cyl.1-Fuel Inj.Circ. Open Circ.
| 17647 | P1239 | Cyl.3-Fuel Inj.Circ. Open Circ. <------ try tightening your gas cap
| 17648 | P1240 | Cyl.4-Fuel Inj.Circ. Open Circ.
| 17646 | P1238 | Cyl.2-Fuel Inj.Circ. Open Circ.
18010 Power supply terminal 30 P1602-35-10 intermintent <-------usually associated with disconnecting the battery.
Old Jan 11, 2005 | 01:21 PM
Walls's Avatar
Yo Jestnomen,
This sounds expensive... I aint that mechanically endowed... but I think I can manage to tighten the gas cap... the rest I'll leave for a professional..
taking it in again tomorrow.
Wish me luck
W
Old Jan 11, 2005 | 06:19 PM
Jestnomen's Avatar
6th Gear
Nah none of those are very expensive. You can do most of it yourself very easily. The coolant temp sensor is like 40 bucks or something, and an easy replacement.
Old Jan 13, 2005 | 07:31 PM
Walls's Avatar
Hey Jestnomen,
I had the car checked and they say its the coolant temp sensor... if its very easy to change it my self... I'm willing to give it a go... guide me... please
