engine noise
Old Sep 10, 2005 | 04:26 AM
dubiousmusic's Avatar
Default engine noise
i know this topic is on here somehwere but i couldnt find it. my engine makes a sort of ticking sound when in idle. how much does the repair for this usually go for?
Old Sep 11, 2005 | 10:16 PM
2k2nyc's Avatar
Default RE: engine noise
Same here....this is my second Audi and both make the same noise.
Old Sep 11, 2005 | 10:17 PM
germancarmaniac's Avatar
i think its normal because mine does it to
Old Sep 13, 2005 | 02:03 AM
does anybody know if this is somthign that should be fixed in a hurry or just if i ever get around to it
Old Jun 8, 2006 | 06:34 PM
browndognj's Avatar
I have a similar ticking noise, I can'f figure out if it's the hydraulic lifters, or valve tap or something else, in the end what was the problem? thanks, Browndognj.
Old Jun 8, 2006 | 06:39 PM
a4sport's Avatar
Join the club. My B6 is also doing that now. Sound like it coming from the side of the engine closest to the firewall.
Old Jun 8, 2006 | 06:48 PM
onepoint8tee's Avatar
If the ticking is coming from the airbox area, there is a valve there that ticks when air goes through it, the ticking means its working.. And should be pretty mild but noticeable with the hood open. Other ticking could be from the cam tensioner on the firewall/top side of the engine. If the tensioner gets worn out the chain slaps around and hits the valve cover (this is seperate form the timing belt on the front/radiator side of the engine.) Other than that, it could be valves that need adjustment, or your hydrolic oil lifters. A good first stp is changing the oil, or doing an engine flush. All this has been covered many times and you can read more about it and other peoples experiences with it by searching "engine noise." Or "ticking." Or "cam tensioner chain" etc.
Old Jun 8, 2006 | 06:53 PM
a4sport's Avatar
See, I thought mine was the cam tensioner since it's coming from the top of the engine by the firewall. Just need to take the time to get it done one weekend.
Old Jun 8, 2006 | 08:41 PM
ORIGINAL: a4sport
If your gunna do it yourself make sure you get a couple good DIY articles or engine tear down diagrams.. its not as easy or cheap as you might think.. But thats just what ive heard.
Old Jun 8, 2006 | 11:01 PM
a4sport's Avatar
I hope to figure it out one of these days. Like you said, I'll be doing lots of checking into it before I dive in head first.
jraffoul
Apr 10, 2017 06:10 AM
kenman
Sep 12, 2012 02:34 PM
tj19855
Dec 31, 2007 03:28 AM
tbrown
Sep 11, 2006 02:47 PM
