Engine Revving When You Start Engine
Old Jun 25, 2005 | 08:03 AM
Jayo's Avatar
Default Engine Revving When You Start Engine
We have a problem with our 2000 Audi A4 1.9 TDI. Everytime we start the car it revs just like you were putting the throttle down, only we don't touch the throttle. Any ideas what is causing this problem? I would appriciate any help.
Old Jun 25, 2005 | 10:12 AM
david9999's Avatar
Default RE: Engine Revving When You Start Engine
Hi welcome to the forum. Unfortunately, most of the people here are US based, and the TDI isn't available here in the Audi, so epxerience with deisel engines is weak. Still someone may be able to help.
The general suggestion is to find someone with a VAGcom who can check for engine codes. There is a link at the top of the board to important audi information. Click on the VAGcom locator and see if anyone has one local that they may allow you to borrow.
Does the car do it both when initially starting it after overnight and if the engine is warmed up and you try to restart?
Old Jun 25, 2005 | 04:26 PM
Shaunp05's Avatar
hi
Since it is Deisel, it controlled by the amount of fuel added to the engine,
not air, air remains the same,
Does it flare up to like 1200rpm or more ?
There do that sometime coz its a high comprssion engine
and there is not much A/F controll on start up
Old Jun 25, 2005 | 05:06 PM
Jayo's Avatar
As soon as it's warm, If I restart the car works and sounds fine. It's only when the engine is left overnight. It's never done it before, and it's only recently started to do it, also black smoke comes out the exhaust each time aswell, but doesn't come out when the engine is warmed up.
Does it flare up to like 1200rpm or more?
It flares up to 2500rpm!!
Old Jun 25, 2005 | 08:31 PM
Dave666's Avatar
lol
Old Jun 25, 2005 | 09:30 PM
Shaunp05's Avatar
Fuel Issue, Black smoke on this engines its running to rich
Have it looked at, it might be time for an injector service and pump recalbaration
make sure you using good fuel as this are **** to injector nozzels getting dirty
if Primary and secondary filter are not changed on time
Old Jun 25, 2005 | 10:48 PM
david9999's Avatar
Not sure how deisel works or whether there is a "starter injector" that enriches the mixture for initial start with the glow plugs.
danny_sykes_18
Aug 21, 2013 02:27 AM
mikeysline06
Nov 4, 2010 10:32 PM
jesse5841
B7 Models
Feb 28, 2010 05:17 PM
BarefootPanda
Jan 20, 2008 03:16 PM
ellenbec
Nov 23, 2004 10:58 PM
