Sponsored by:
Sponsored by:
SS install question, help..
Old 01-01-2007, 01:37 PM
McGuireDennis's Avatar
Default SS install question, help..
Guy no matter what I did I couldn't get these screws out, I was going insane my hands are blistered from twisting the tool.. Is there something I need to know to get these screws out.. And also what size are these nuts cause the bottom one I couldn't even find a socket to fit it..
[IMG]local://upfiles/25696/E66D6C69B32A4ECAA5C2C6D3BD5AC1E3.jpg[/IMG]
Old 01-01-2007, 01:47 PM
dankhound's Avatar
Default RE: SS install question, help..
Looks like 8 or 10 mm. Try turning it with an open end wrench. My guess is that the whole nut and stud are turning.
Old 01-01-2007, 06:10 PM
AteUrV8's Avatar
wd-40, lol.... if that doesnt work, its like 30 minutes for a shop to install one... so $37.50, thats probably the cheapest thing to sit back and let someone else do the work for you.
Old 01-01-2007, 07:08 PM
luvin_the_rings's Avatar
u dont have a wrachet...?
go to pep boys and get some penetrating lube...
that part's the easiest, the other bolts are in the worst place
Old 01-01-2007, 07:53 PM
turbo kraut's Avatar
Tech Guru
it is a 10 mm and the ones under there are harder to do
Old 01-01-2007, 08:14 PM
1.84life's Avatar
yeah when i did mine those came right out easy, i used a socket wrench with the right bit on it forgot the size tho, but small.
Pbcrazy
06-05-2013 04:56 AM
cantdrive55
07-26-2008 09:59 PM
mbertoli
01-16-2008 02:24 PM
mikejda
04-07-2007 09:26 PM
krue92
07-26-2005 06:56 PM
Quick Reply: SS install question, help..
