Entering the radio code
iv read up on the radio code topics on this forum, i have the radio code but not sure which buttons to press to enter it for my 1999 a4 1.8t mode/scan? fm1/am am/scan i dont know the procedure if anyone could tell me the correct procedure to let me enter the codes that would be great
its in the manual - your radio manual to be exact - also post what kind of radio you have - not sure if that matters but I have a symphony and I know there is a concert, don't know what the difference is
I clicked the little button at the top of the page that says search - I entered in "Radio Code steps" here is a copy of what I found in 3 minutes.
Turn on radio. The radio display shows "SAFE".
Press the FM2 and RDS buttons simultaneously and hold until "1000"
shows on the display. Release the buttons. Do NOT press these
buttons again, otherwise the radio will consider "1000" to be
the code.
Use Preset buttons 1 ... 4 to enter the four-digit code number
from your radio card. Preset button 1 corresponds to the first
digit, Preset button 2 corresponds to the second digit, etc.
Each press of the button increments the number by 1.
Once the code shown on the display is correct, press the FM2
and RDS buttons simultaneously and hold until the word "SAFE"
appears in the display, then release the buttons.
The radio should unlock and be usable shortly afterwards.
If an incorrect code is entered, the word "SAFE" appears,
first flashing and then continuously. You can repeat the
above steps to unlock the radio once more, the number of
attempts will be shown in the display. If an incorrect code
is entered again, you radio will be locked for about one hour.
After one hour - the radio must stay on and the key must remain
in the ignition lock - if the display goes out, the you can repeat
the above procedure to unlock again. The cycle - two attempts, one
hour lock-up - still applies.
If you lose your radio code, contact your Audi dealer.
Note: Some European market Concert radios have a TP button instead
of the FM2 button, so the description above with those units would
require pressing the TP and the RDS buttons simultaneously.
the code.
I recently bouight a 2001 Audi Allroad that has a later model Symphony installed, the type where 6 cds can be loaded directly into the radio without using the cd changer in the back of the car.
Recently, I changed the battery and now the radio is in safe mode.
I have read mutliple threads on the procedures to enter the security code but I can't even get to that step.
It's simply stuck on SAFE, I am at a loss.
My friend told me I may need to flach the ECN with a ross-tech vag com.
Also, the radio lights behind the buttons do not work or the steering wheel controls such as volume etc. The LED does work though. Not sure if this factors in or not.
Any ideas?
Any ideas?
