Fault Code Diagnosis & Repair
Old Mar 15, 2007 | 07:54 PM
b_coulombe's Avatar
Default Fault Code Diagnosis & Repair
Hi
Could someone who's tech certified or experienced in this matter please lend some assistance.
17887 - Brake Boost Vaccum System: Mechanical Failure
P1479 - 008 - Implausible Signal - Intermittent
I'm assuming theres a leak in a vacuum line, how do I go about finding the problem and rectifying it.
Thank you.
Old Mar 16, 2007 | 04:10 AM
akielb's Avatar
Default RE: Fault Code Diagnosis & Repair
17887/P1479 possibly your vacuum pump failed, needs to be checked out, or this is what searching the form can get you https://www.audiforums.com/m_364038/tm.htm
Old Mar 16, 2007 | 09:25 AM
david9999's Avatar
First clear the code and drive for a couple of hundred miles and see if it comes back. If not, it is an old code that happened some time in the past for some reason.
Old Mar 16, 2007 | 11:49 AM
b_coulombe's Avatar
Thank you
cordawg92
May 20, 2016 12:15 PM
deem2000
Jan 22, 2012 01:23 PM
AudiFam2003
Dec 30, 2011 05:11 PM
Jayjay
Feb 14, 2008 03:47 PM
adotjdot
Nov 16, 2007 04:48 PM
