Few Questions.
Im looking at 1999 a4 1.8T with 90k miles
its for around 7k, is this good deal? and if so What kind of problems should I look for and types of questions I should ask? |
RE: Few Questions.
there are a lot of factors but if the car is in great condition thats a desent deal.
make sure the timing belt has been changed ask if there are any mods check for worn tie rod ends and front control arms make sure the sun roof works check for valve cover gasket leaks diff leaks none of these should make you not want to buy the car they are just a good way to talk down price seeing that a timing belt job is almost 1k. also look at the display on the dash. i promise it will messed up, tell them that this dissapoints you and ask for a lower price. |
RE: Few Questions.
Thank you =]
