Finally took my car out
its been a while since i took my car out since i had trouble with the Throttle body which i replaced and reprogrammed ECU, i installed FMIC a while back but never really drove it but when i took it out it sounded insane since i also put CAI but then when i came to a light my car was running like shit and couldnt move but i popped the hood and the intake piece just popped off so it was good then it happened again, could it be i just didnt tighten hose clamp or is something wrong?
RE: Finally took my car out
Are you running T-bolt clamps if not you will continue to blow off the intercooler piping becase of boost pressure make sure everything is extra tight.
will do. also, after driving it for a while i came up with these codes, 16505, 16684 two times and 16688 two times also, so it was a total of 5 codes but 2 were duplicate?????????? Whats wrong?
first code is TP sensor ( poor connection )
second is a misfire on pot 4 |
lol pot 4 ??? you and your silly talk...
ORIGINAL: avant80@2.6 first code is TP sensor ( poor connection ) second is a misfire on pot 4 |
got it. will check the connection on that and what would cause that on Pot 4?
