AudiForums.com
-   Audi A4 (https://www.audiforums.com/forum/audi-a4-8/)
-   -   Finally took my engine covers off (https://www.audiforums.com/forum/audi-a4-8/finally-took-my-engine-covers-off-46632/)
nickt1216 Nov 15, 2006 06:08 PM
https://www.audiforums.com/m_381900/tm.htm
This is a continuation of an old post of mine. ITs about my car having weird noises while it starts up and how it smokes around the engine bay. The weather has been really rough around my area so i haven't had the opportunity to get any thing done. But today it was nice and so i took the opportunity to take off my engine covers and capture some close up photos and video for everyone to see. I haven't drivein my car since all the issues started occuring. I'm also aware i should drain my coolant/antifreeze.
Car starting up, it has a horrible start up sound; 7 megs
http://www.computersharp.com/nickt/DSCN4794.wmv
Car 1 minutes later, engine sound changes; 4 megs
http://www.computersharp.com/nickt/DSCN4795.wmv
Car 2 minutes later, engine sounds differently and you can clearly see the smoke in the video; 3megs
http://www.computersharp.com/nickt/DSCN4788.JPG
http://www.computersharp.com/nickt/DSCN4789.JPG
http://www.computersharp.com/nickt/DSCN4790.JPG
http://www.computersharp.com/nickt/DSCN4791.JPG
http://www.computersharp.com/nickt/DSCN4792.JPG
http://www.computersharp.com/nickt/DSCN4793.JPG
So what do you guys think i should do?
aRIf Nov 15, 2006 06:14 PM
RE: Finally took my engine covers off
why do you have green low coolant ? is it different on V6 ?
onepoint8tee Nov 15, 2006 06:18 PM
How about getting rid of the nasty green stuff and filler up with the correct G12 pink stuff??
As far as the sound, what type/grade oil do you use?? How many miles?
The bad sound could be from a dying water pump due to running not enough/incorrect coolant. They get noisy and bearings get worn if you run with a low coolant level over time.
GeilKyle2 Nov 15, 2006 06:34 PM
if you dont' know a lot about cars, I may suggest you take it somewhere to have your concerns looked at...and really in the video I don't really hear a hole lot other than lifter tick, chances are you have a collapsed lifter on start up and once it build oil pressure it fills the lifter again with oil. And yeah ditch the green stuff, and thats not your timing belt that you pointed out in the vid, the timing belt is hidden under all your plastics yet.
GeilKyle2 Nov 15, 2006 06:39 PM
and as far as smoke around the engine bay, i'd go with the fact of leaking valve cover gaskets causing oil to be burnt on the manifolds or cylinder heads
18T Nov 15, 2006 06:58 PM
youve got oil leaking. check gaskets
onepoint8tee Nov 15, 2006 07:07 PM
Everytime i see the green stuff in an Audi it makes my stomache turn almost as bad as seeing a type R sticker on a Mustang.
00A41.8Quattro Nov 15, 2006 08:14 PM
ORIGINAL: onepoint8tee
LOL or how about a VTEC stick on a Daewoo with a lightup APC fart cannon.
GTOrleans Nov 15, 2006 08:24 PM
lol...i forgot which forum it was on but some guy removed all the badges, then rebadged it with 2.0T, a FSI badge and his quattro logo, definetely needed a type-r logo, or chrome gas door cover to finish it off. "Debadge, don't rebadge!"
nickt1216 Nov 16, 2006 12:45 PM
So i should flush my coolant and put in g12, universal yellow, or dex?
