finished hooking up my sub/amp
Well it ended up being a two day process but its finally done. the owner of the car before me hacked up the system a bit, the rear speakers didnt work so when i hooked up the line output converter it wouldnt turn on. when i took the rear speakers completly out the doors it worked! well now I have to replace the rears and will probably replace the fronts while im at it with a nice component set and a 4 channel amp. Well i put a 10" kicker comp and kicker kx350.2 and its perfect. once i replace the interiors i will be in business.
RE: finished hooking up my sub/amp
PIIIIIIIIIIIIICS! we damand pics
Sounds nice, literaly. I used to be really into that when I had room in the car to do it.
yea i used to be into audio like crazy with my 96 camaro. 6 10" thunder 5000's in a custom box 4 across facing up, 2 on the bottom facing forward, and 2 lanzar optidrive 2200. Lets just say my hearing was effected by it. Then in my mustang I went straight for speed. for the audi I plan on a bit of both. oh and the previous owner already has the trunk dynomatted :D ill post pics tomorrow
those MTX were the sh!t.
i used to have two THUNDER 8000s each 1000watts each with a 1600watt amp
that was crazy bass but those days are over |
