First VAG COM Reading
Old Mar 31, 2005 | 01:34 PM
Hecareth's Avatar
Default First VAG COM Reading
Ok so I finally decided to read my car before I went out buying stuff and this is what it found...
So I figure I need a new O2 Sensor, but what about these three other faults. Please help
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 8D0 907 557 P
Component: 1.8L R4/5VT MOTR AT D04
Coding: 06251
Shop #: WSC 06335
4 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17956 - Boost Pressure Regulation Valve (N75): Open Circuit
P1548 - 35-00 - -
17091 - Transmission Range Sensor (F125): Signal too Low
P0707 - 35-00 - -
16806 - Main Catalyst: Bank 1: Efficiency Below Threshold
P0422 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 02 -------------------------------------------------------
Controller: 8D0 927 156 BN
Component: AG5 01V 1.8l5VT USA 8508
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D00
Coding: 0273004284
Shop #: BB 24334
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 D
Component: A4 KLIMAVOLLAUTOMAT_D75
Coding: 04142
Shop #: WSC 06335
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 910 P
Component: B5-KOMBIINSTR. VDO D05
Coding: 02242
Shop #: WSC 19411
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 N
Component: CV-Pump D10
Coding: 16232
Shop #: WSC 06335
2 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06335
Address 56 -------------------------------------------------------
Controller: 4B0 035 186 A
Component: Radio D02
Coding: 00207
Shop #: WSC 40815
2 Faults Found:
00854 - Radio Display Output in dash Panel insert
49-00 - No Communications
00855 - Connection to CD changer
49-10 - No Communications - Intermittent
End -------------------------------------------------------
Old Mar 31, 2005 | 02:22 PM
Jestnomen's Avatar
6th Gear
Default RE: First VAG COM Reading
ORIGINAL: Hecareth
Coding: 06251
Shop #: WSC 06335
4 Faults Found:
P1602 - 35-10 - - - Intermittent <-------------------usually when the ECU or battery has been disconnected
P1548 - 35-00 - -
P0707 - 35-00 - -
16806 - Main Catalyst: Bank 1: Efficiency Below Threshold <----------clear this code and see if it returns in a week
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
00526 - Brake Light Switch-F <--------------------------- http://www.ross-tech.com/vag-com/faq_2.html#DTC-Ignore
Coding: 16232
Shop #: WSC 06335
2 Faults Found:
01370 - Alarm triggered by Interior Monitoring <------------------------just means the alarm went off, no biggie.
35-00 - -
00956 - Key 2
Coding: 00207
Shop #: WSC 40815
2 Faults Found:
00854 - Radio Display Output in dash Panel insert <-----aftermarket radio? Clear code and see if it returns.
Old Mar 31, 2005 | 09:57 PM
david9999's Avatar
17956 - Boost Pressure Regulation Valve (N75): Open Circuit Self explainatory. Wastegate regulator may not be working. Clear the code and see if it returns.
Through the multi-function Transmission Range (TR) program switch -F125- at the transmission, the Engine Control Module (ECM) recognizes whether a drive range is selected (selector lever in 2/3/4/R/D) or not (selector lever in P or N)
Clear and see if it returns
00956 - Key 2
Key not matched
Key operated more than 200 times while out of range
If your remote key works, clear the code. If your key doesn't work, then reprogram it.
Old Mar 31, 2005 | 10:02 PM
brrman's Avatar
I would clear everything and see what comes back within a week.
Old Mar 31, 2005 | 10:03 PM
david9999's Avatar
16806 code is not an oxygen sensor, but a failing catalytic converter. Is yours OEM or is it an aftermarket replacement? Clear the code and see if it returns
Old Apr 2, 2005 | 04:32 PM
Hecareth's Avatar
I cleared the codes, and unfortunately all of them returned. I am taking it to my mechanic on monday to see whats up. If possible I would love to fix everything that may be simple, I found where the boost pressure valve is with the help of my haynes manual and where the knock sensor is, however I have no clue where this transmission range senor is, and it is not in the Haynes manual.
Old Apr 2, 2005 | 04:53 PM
Hecareth's Avatar
This may be a dumb question, excuse me if it is, but would any of this be related to a bad DV valve?
Old Apr 2, 2005 | 05:24 PM
Hecareth's Avatar
David,
my converter is OEM, but if it is failing shoudn't I bee smelling some foul smell in the air when driving? Also it may help to add my gas mileage is 15 MPG and the car revs too high before it shifts, kinda rough. I figure that might be the transmission range sensor problem.
Scaryfatkid
Jun 1, 2010 04:17 PM
AudiCross
Apr 16, 2010 04:15 AM
Yerfdog006
Mar 17, 2007 08:19 PM
A4_1.8_20v
Jan 10, 2006 01:24 AM
blades
Oct 8, 2004 09:04 AM
