flashing engine light and bs mechanics
so my car idles like the engine is going to break off the mounts and i have a flashing check engine light. stops shaking around 3k. took it to the mechanic and he says i have a misfire in my one cylinder. Changed the plugs, coil pack still same thing. OK now he's 99% sure its the injector......replaced it today and still the same thing.... i am getting severly pissed and can't drive my car... i guess now i'm thinking fuel pump.....anyway to check at home before i go buy another useless part...... thx
Given what you have already changed, my guess is that you probably have a bad ICM (ignition control module). The best way to check it is with a voltage meter. To check it, unplug the connector on the coil pack side (should be 4 prongs), turn the key to the on position and check the voltage at every connector--they should all be nearly the same. I can't remember what the exact reading should be. I'm sure you can find it if you search around. Make sure you check it before you replace it. Those things are fairly expensive.
Also make sure you get a scan now and report the codes.
If you had a bad fuel pump you would misfire on more than one cylinder.
I work on a Army base and it happened at work 40 miles from my house, I took it to the garage at my work... he scanned and it reported misfire in two cylinders. Also returned code 1300 which he said is ignition. I am taking it to AP tuning on thursday which specialize in Audi.... around how are we talking for an ICM? thanks for all the replies
Is it ok to drive when the CEL is steady on? I have a misfire in cylinder 2 that isn't fixed yet, but I just haven't had time to figure it out. Autozone codes were p0300 and p0302. I changes coils and plugs to no effect.
