Forge DV
ORIGINAL: Papachristou
what is the difference in the OEM 710 and the aftermarket 007 model?
i really don't think i'm going to build the engine anymore than just the apr chip and intake....so what color spring would i use in the 007? or would i be better of just getting a stratmosphere/hyperboost, so i don't have to worry about different springs?
ORIGINAL: Boober
ORIGINAL: Boober
ORIGINAL: Boober
does the 007 come with the yellow spring in it, or would i have to buy the spring kit and change it out to the yellow spring? the car is a 2000 1.8t, w/APR chip...it says 200hp/2**lbs (don't remember off hand) so would the green spring work as well, how much difference is there between green and yellow?
Im pretty sure youll have to get the spring kit. People that are chipped prefer the green spring from what i know. I dont know whats in mine cuz i bought it used and just installed it. It holds about 20 psi and boost comes on and goes off nicely.
ORIGINAL: Boober
onepoint8tee: according to above, should i be using yellow instead of green? when do you want the DV to divert? could this be why I'm spiking at 24-25 at WOT? once I get the 93 program how much more psi will I be getting? i'm afraid of hurting my little turbie!
.clipse
May 15, 2007 11:55 AM
