Forge RACE Diverter Valve VS.Forge 007 Diverter Valve
Old Apr 6, 2007 | 02:57 AM
onepoint8tee's Avatar
Default RE: Forge RACE Diverter Valve VS.Forge 007 Diverter Valve
ORIGINAL: Mr_You
Personally I don't see the reason to spend that much money on a diverter valve. I mean go for it if you want. Maybe someone can explain the reason for getting one of these.
I chose the Bosch "Sport 110" diverter valve which is stock on the Porsche 996/911 Turbo. It can handle high boost. AFAIK the only difference between it and the 710N is the spring.
Part number is 0280142110 ... I bought mine off thepartsbin.com for about $55.
EDIT:
Oh, I see the sound is important to some people. I guess thats why. To each his own.
You get a lifetime warranty by paying "that much money" and the overall design compared to yours or a 710N dv is much better. Your dv uses a rubber diaphragm that can be easily torn or deteriorate. Springs do wear out, and a serviceable DV is important when that happens. If you were to keep your car for 5+ years running 20psi or more, youd go through at least a couple Sport 110's or 710N dv's. If you have a BT, plastic/rubber diaphragm DV is out of the question.
I ran a 710N and itfailed after about 9k miles of boosting 20 psi...
Old Apr 11, 2007 | 01:36 PM
patty AT forge's Avatar
ORIGINAL: Mr_You
I just shipped 50 007 valves to a Porche tuner... Apparently their stock valves aren't holding up too well
Old Apr 11, 2007 | 03:02 PM
2k S4's Avatar
If you are stock, or "just" have a chip, the 710n is a great DV! However, if you want to upgrade the car, & get a bigger turbo, you will NEED an adjustable DV. The 007 is a great choice! Not only is it rebuildable, but you can tune it with the $17 shim & spring kit. All the 007's are about the same, the difference is the top cap & one lets you swivel the vacuum port, it's on the side instead of being at the top. So it comes down to, do you want a smooth DV, one with a hex hed top, or one with a swivel top? Internally, they are all the SAME!
The stock DV opens at 10psi, the 007 stock opens at 14psi, I set mine to open at 17psi. Boost creep, sucks!
No you will not get the BOV sound with any DV, you can get some noise, but you will NOT get the SWOOSH noise.
Old Apr 13, 2007 | 12:16 PM
ORIGINAL: 2k S4
...The 007 is a great choice! Not only is it rebuildable, but you can tune it with the $17 shim & spring kit. ...
Actually the 007 valves all include a partial spring tuning kit that will have you covered from 5-30 psi of boost.
An open air intake will net you a sound very similar to a vent to atmosphere valve... or you can give this a shot:
http://www.forgemotorsport.com/conte...duct=FMDVSPLTR
Old Apr 13, 2007 | 12:50 PM
Jeff's Avatar
Zombie Defense Force
how about teh rs. its fully adjustable just by turning a **** on the top
Old Apr 13, 2007 | 03:09 PM
2k S4's Avatar
ORIGINAL: patty AT forge
Mine didn't come with anything. The other ones I have seen don't come with any adjustment shims or springs. Even the Forge web page states you have to purchase the kit separately.
Old Apr 13, 2007 | 11:20 PM
socal_A4's Avatar
Dtmguy sent you a pm
Old Apr 16, 2007 | 03:04 PM
  #18
ORIGINAL: 2k S4
PM me with the name of the company that you purchased your valve from. Every real 007 that is sold in this hemisphere is recieved at my office and inventoried by yours truly. I can assure you that they leave this wharehouse with a partial spring tuning kit that includes the green, yellow and blue springs along with two shims. This has been the case for well over a year now.
Old Apr 16, 2007 | 03:24 PM
  #19
2k S4's Avatar
Oh, that sucks! I spent the extra $30 to get the adjustment kits!
rwf0011
B7 Models
13
Sep 13, 2010 07:09 PM
blkapra4
12
Mar 10, 2008 12:22 AM
Flip
9
Jan 28, 2008 11:18 PM
EVOLA4
Jul 10, 2007 02:29 PM
blkapra4
Oct 27, 2006 08:04 PM
