Front calipers need help
it has come down to replacing my pads and i got the caliper off and when i went to compress it it will not go in all the way is there something i am messing this is on the Front passger side on a 96 Audi A4 let me know if there is something i need to do diff
RE: Front calipers need help
I haven't done a brake job on my A4 yet but you probably need to turn the piston while compressing it. You can buy a tool for this at most Autoparts stores or you can compress it with a clamp while turning the piston with a pair of channel locks (pliers)--but be careful not to rip/damage the boot around the piston.
I used the second method the first time I ran into this problem...I couldn't figure out for the life of me why the piston wouldn't go back in and then tada success and I didn't even realize how I did it so I how to fiddle with the other side for like 20 mintues.
ORIGINAL: skidplatexa4
The rears need to be turned in because of the ebarke the frontd should just compress back in.
Yep, the C-clamp is all I've ever used... I've used needle nose pliars to turn the pistons back before. Annoying as hell. Then I took an old socket, and ground around the top, leaving two little prongs... so I can use a ratchet, and push against the piston as I turn the ratchet.
That, OR loan the tool for free from canadian tire. Whichever :P
yes i have done many brake jobs. i come here cause this is the 1st one that it will not comprss back in i have the the tool for brake jobs and i have put the pad in with that tool and twisted the it to it could no longer turn i have no clue maybe the caliper is broke when i look at it i see the black ylinder that i need to compress but i also see this silver thing right behhind it also i think its the piston i will take a pick later tomorrow to show you
