Fuel in Engine Oil
Why is that? I changed the oil about 800 miles ago and I start to smell the fuel in the oil. That's not good.
What seal or what cause of this problem? What do I need to replace it ? Any ideas ? |
RE: Fuel in Engine Oil
Well... It could be that you're running way rich. Maybe worn rings...
Change your PCV valve.
^ that too
Hope it is PCV.
Do you guys have any pic where it is located. It's not top ot my head right now. I want to check at mybreak. |
PCV is directly abover the N75 - its the "puck valve"
also called the 034 valve in a picture on this DIY http://www.scottweese.com/images/pcv/pcv.html |
the oil in my old lexus always smelled like fuel. the mechanics told me there's no fuel leak.
$0.02 |
akielb, it's a great info. Thanks a lot. I think I found something to keep me busy this weekend :)
I thought when you run an oil catch can, it eliminates the pcv valve?
Oil catch can catch the oil which goes back to the intake.
Fuel in engine should nothing to do with it, I think. People in AZ say it could be compression rings. Ones I get it that close to the block, it'd be better to rebuild the whole thing. onepoint8tee; do you have compression test stuff ? I wanna do compression test see what's up. |
