fueling needs for 1.8t K04
Old Oct 25, 2010 | 12:40 PM
brolo747's Avatar
Default fueling needs for 1.8t K04
I've recently been upgrading my car slowly... as my budget allows. I have a '99.5 1.8t (AEB) I have the upgraded turbo inlet hose, k04 turbo, a custom 2.5" downpipe to mate to the stock exhaust (for the time being) My question is do I need a higher fuel pressure regulator and/or injectors? And if so, with injectors and/or fuel pump installed, will I need a rechip to run correctly or rather not ruin or damage the fuel system? I mean can I install higher pressure injectors and fuel pressure regulator with OUT a chip-up or will I ruin things if I run the car in that condition? My car is also a tiptronic ( i know awful) I seem to be having issues with the solenoids in the tranny... I am thinking I will order a kit to replace them all and the wiring harness. Does anyone know if this problem could be related to fueling problems? Thanks for any help/info in advance.
Old Oct 25, 2010 | 03:41 PM
turbo kraut's Avatar
Tech Guru
this has been covered a million times, but you can run with stock program but won't notice much of a difference... you don't want to or need to upgrade anything fuel related if you have not done a tune... and there are a few tuners for your car/model yr... and you will need to upgrade fueling according to their specs
Stephen Thomas Kraus Jr
May 7, 2012 05:31 PM
smashed s4
Jan 27, 2012 02:41 AM
morris400
Sep 6, 2011 10:06 PM
mbender
Mar 25, 2010 11:15 PM
$4Jordan
Nov 19, 2008 12:10 AM
