FWD Rear Coilover Install
Old Jul 16, 2007 | 11:26 AM
SouRce4's Avatar
Default FWD Rear Coilover Install
Has anyone with a FWD A4 performed a coilover install? if so the fronts are the same as quattro but to take out the rear shocks seems as tho there is one bolt and thats it? can this be?
Old Jul 16, 2007 | 12:19 PM
EliteTuning1's Avatar
Default RE: FWD Rear Coilover Install
i did spring on my fwd. i went through the same thinking your probably going through right now. there is one lower bolt at the bottom of the shock, and up top is the hard part. you have to take off the side pieces next to your seat. first take out the bottom of the seat by pushing down ard once on the edge and then pulling up. now you should see the bottom of the side piece held in by a metal hook. bend it with your finger and pull the side piece off. now look to were the shock goes up into the car. there should be a piece of foam wedged in there. take that out and that will expose the 3 top bolts that need to come out to get the shock assembly out. i hope this was kind of clear, be sure to ask any questions you have. i know how lost i was when i went to do mine. i wish i had someone to help me.
Old Jul 16, 2007 | 01:24 PM
SouRce4's Avatar
i got it out thanks. the question i have now is there is a black tappered peice with 4 clips on the end or it. (the top of the shock) how do i take off the hat to get the spring off?
Old Jul 16, 2007 | 01:59 PM
stick a flathead in the middle wear the black seal meets the metal. pop that off and it will expose a bolt
Old Jul 16, 2007 | 03:23 PM
i wanna see some pics when it's done!
Old Jul 16, 2007 | 11:50 PM
SouRce4's Avatar
very good. worked well and every thing is on and nice. 2mm i will adjust the heights so that i have a sick stance and all will be well. Thanks again and i will be sure to post my baby's pics lol
Old Jul 17, 2007 | 12:16 PM
i wanna see. did you slam it???
Mr. Phil
Mar 6, 2010 01:31 AM
Ryder
Dec 22, 2009 09:58 PM
ryan2391
Mar 14, 2009 06:57 PM
meatbiscuit
Nov 26, 2007 11:49 AM
twenty8red
Oct 26, 2007 09:56 PM
