Gas milage and extreme cold
I am probably stupid and should know the answer to this question but I will ask it anyway. Does extremely cold temps effect gas milage. Driving home tonight and temps are hovering around 15 degrees, going 65 mph and was getting about 19 mpg.
RE: Gas milage and extreme cold
See dumb question on my part, should have known that one. Yea had the heat on 75 and pumped up. I will watch tomorrow and see what happens but I bet that was it. Thanks Cary12.
Yeah I agree with Panda some. I think you are supposed to get better fuel mileage in warmer weather. I always thought it related to expansion and vapor pressure and all of gasoline. Pandas theory makes better sense for the engine end. So combine the two and run some thermodynamic calcs and get back to us.
Two things actually(although one is a rumor) -
Rumor is Winter grade fuel (at least in most parts of the country) is a different mix than summer to combat pollution and for some reason this fuel mix gives less MPG than typical.
Fact - as stated above - cold air = denser air charge = more air = more fuel for constant A/F ratio = more power
ORIGINAL: PandaXpress
u kno i think the cold weather would effect milage casue
colder air means denser air so to compinsate for this
you must use more fuel so u dont run lean
thats my theory
thats my theory
