Glove Box Problem...
Old Jan 16, 2006 | 07:00 PM
ZedEx's Avatar
Default Glove Box Problem...
You know on the B6 A4s (Same thing on the B5s I'm sure) when you open the Glove Box, it goes down slowly... Well mine's always done that, and today I opened it, and it just flopped open, with no resistance. It feels like it's not catching, does anyone have any idea what this is? I can't stand it when little crap like this goes bad, because it's always a royal pain in the ***.
Old Jan 16, 2006 | 07:07 PM
PandaXpress's Avatar
Default RE: Glove Box Problem...
my glove is doin the same thing now also
that think just flys open
Old Jan 16, 2006 | 07:09 PM
VB05's Avatar
my handle (B5) snapped off recently and the release mechanism that was attached to the handle cracked i believe. So I had to jimmy my way in with two screwdrivers to get my registration and insurance out just in case.
Old Jan 16, 2006 | 08:22 PM
ZedEx's Avatar
Hmmm... Anyone know? I'm on the verge on pulling everything apart.
Old Jan 16, 2006 | 08:28 PM
Kellya4's Avatar
It should just be a gear w/ restistance that lowers it slowly, at least that's what it has been on other cars w/ this type of stuff that i have fixed. It's just a plastic gear that can get stripped out easily, but i have not pulled the on out of the Audi.
Old Jan 16, 2006 | 10:33 PM
AudiTech04's Avatar
Pull of the side panel cover on the pass side
Its just like the one covering the fuse panel and look at the bottom of that area
There is a cylinder type thing that releases the the door might have just came loose
Old Jan 16, 2006 | 11:34 PM
mastvadz71's Avatar
Member
no it is not onthe outside it is pass site but the one close to the centerconsole.the re is a small cylinder .check it out it is not a big deall,poss the piston came out of the cylinder
Old Jan 17, 2006 | 12:55 AM
ZedEx's Avatar
I clipped the fitting back in, and reconnected the clip for the light... And the fitting keeps popping back out if I don't assist the glove box door in opening... i.e I have to let it down real slow.
I can't see how I can replace it... Anyone have any ideas?
Old Jan 17, 2006 | 01:05 AM
AudiTech04's Avatar
ORIGINAL: mastvadz71
No no no it is definately on the right side of the glovbox
Anyways Back to the problem at hand
I cant really remember how it comes off but i think there is probly a screw or something like that to hold it on, I know its replacable i remember doing one
Old Jan 17, 2006 | 01:27 AM
ZedEx's Avatar
Well that's good to know, it seems like there's supposed to be a clip on the inside of the bracket that's supposed to hold it in... I think it may have popped off. Is there a clip that secures it in place?
Jeffrey Stundon
Mar 3, 2013 04:50 PM
DELB
May 12, 2011 06:29 AM
JMaN05
Nov 29, 2006 06:40 PM
kingming
Oct 2, 2005 02:13 PM
Tailsan
May 10, 2005 01:58 PM
