Got Vag Codes? Wonder what they mean?
RE: Got Vag Codes? Wonder what they mean?
nice find!
Very Good Find. Make a Sticky
First digit structure is as follows: * Pxxxx for powertrain * Bxxxx for body * Cxxxx for chassis * Uxxxx for future systems Second digit structure is: * P0xxx Government required codes * P1xxx Manufacturer codes for additional emission system function; not required but reported to the government Third digit structure is: * Px1xx measurement of air and fuel * Px2xx measurement of air and fuel * Px3xx ignition system * Px4xx additional emission control * Px5xx speed and idle regulation * Px6xx computer and output signals * Px7xx transmission * Px8xx transmission * Px9xx control modules, input and output signals The fourth and fifth digits designate the individual components and systems. Audi Diagnostic Trouble Codes (DTCs) and data can be retrieved with VW/Audi Factory Scan Tools such as the VAG 1551, VAG 1552, or the new diagnostic computer VAS 5051 through a Data Link Connector (DLC). For location of the data link connector, see Maintenance section. Several aftermarket scan tools and computer programs are also capable of retrieving this information in this factory mode. The factory mode also allows the scan tool to be used for other system diagnostic functions and information retrieval. Some DTC information can also be retrieved in a generic mode. The generic mode is not as complete as the factory mode, but allows commercially available scan tools to be used simply to read DTCs. Generic scan tool mode does not have the capability to retrieve the detailed information of a manufacturer-specific scan tool. Scan Tool Code Table * NOTE - The following table contains a list of available scan tool codes for all Volkswagen and Audi vehicles available at the time of publication. Not all of the codes apply to the vehicles covered by this manual. DTC P-code Description 16394 P0010 -A- Camshaft Pos. Actuator Circ. Bank 1 Malfunction 16395 P0020 -A- Camshaft Pos. Actuator Circ. Bank 2 Malfunction 16449 P0065 Air Assisted Injector Control Range/Performance 16450 P0066 Air Assisted Injector Control Low Input/Short to ground 16451 P0067 Air Assisted Injector Control Input/Short to B+ 16485 P0101 Mass or Volume Air Flow Circ Range/Performance 16486 P0102 Mass or Volume Air Flow Circ Low Input 16487 P0103 Mass or Volume Air Flow Circ High Input 16489 P0105 Manifold Abs.Pressure or Bar.Pressure Voltage supply 16490 P0106 Manifold Abs.Pressure or Bar.Pressure Range/Performance 16491 P0107 Manifold Abs.Pressure or Bar.Pressure Low Input 16492 P0108 Manifold Abs.Pressure or Bar.Pressure High Input 16496 P0112 Intake Air Temp.Circ Low Input 16497 P0113 Intake Air Temp.Circ High Input 16500 P0116 Engine Coolant Temp.Circ Range/Performance 16501 P0117 Engine Coolant Temp.Circ Low Input 16502 P0118 Engine Coolant Temp.Circ High Input 16504 P0120 Throttle/Pedal Pos.Sensor A Circ Malfunction 16505 P0121 Throttle/Pedal Pos.Sensor A Circ Range/Performance 16506 P0122 Throttle/Pedal Pos.Sensor A Circ Low Input 16507 P0123 Throttle/Pedal Pos.Sensor A Circ High Input 16509 P0125 Insufficient Coolant Temp.for Closed Loop Fuel Control 16512 P0128 Coolant Thermostat/Valve Temperature below control range 16514 P0130 O2 Sensor Circ.,Bank1-Sensor1 Malfunction 16515 P0131 O2 Sensor Circ.,Bank1-Sensor1 Low Voltage 16516 P0132 O2 Sensor Circ.,Bank1-Sensor1 High Voltage 16517 P0133 O2 Sensor Circ.,Bank1-Sensor1 Slow Response 16518 P0134 O2 Sensor Circ.,Bank1-Sensor1 No Activity Detected 16519 P0135 O2 Sensor Heater Circ.,Bank1-Sensor1 Malfunction 16520 P0136 O2 Sensor Circ.,Bank1-Sensor2 Malfunction 16521 P0137 O2 Sensor Circ.,Bank1-Sensor2 Low Voltage 16522 P0138 O2 Sensor Circ.,Bank1-Sensor2 High Voltage 16523 P0139 O2 Sensor Circ.,Bank1-Sensor2 Slow Response 16524 P0140 O2 Sensor Circ.,Bank1-Sensor2 No Activity Detected 16525 P0141 O2 Sensor Heater Circ.,Bank1-Sensor2 Malfunction 16534 P0150 O2 Sensor Circ.,Bank2-Sensor1 Malfunction 16535 P0151 O2 Sensor Circ.,Bank2-Sensor1 Low Voltage 16536 P0152 O2 Sensor Circ.,Bank2-Sensor1 High Voltage 16537 P0153 O2 Sensor Circ.,Bank2-Sensor1 Slow Response 16538 P0154 O2 Sensor Circ.,Bank2-Sensor1 No Activity Detected 16539 P0155 O2 Sensor Heater Circ.,Bank2-Sensor1 Malfunction 16540 P0156 O2 Sensor Circ.,Bank2-Sensor2 Malfunction 16541 P0157 O2 Sensor Circ.,Bank2-Sensor2 Low Voltage 16542 P0158 O2 Sensor Circ.,Bank2-Sensor2 High Voltage 16543 P0159 O2 Sensor Circ.,Bank2-Sensor2 Slow Response 16544 P0160 O2 Sensor Circ.,Bank2-Sensor2 No Activity Detected 16545 P0161 O2 Sensor Heater Circ.,Bank2-Sensor2 Malfunction 16554 P0170 Fuel Trim,Bank1 Malfunction 16555 P0171 Fuel Trim,Bank1 System too Lean 16556 P0172 Fuel Trim,Bank1 System too Rich 16557 P0173 Fuel Trim,Bank2 Malfunction 16558 P0174 Fuel Trim,Bank2 System too Lean 16559 P0175 Fuel Trim,Bank2 System too Rich 16566 P0182 Fuel temperature sender-G81 Short to ground 16567 P0183 Fuel temperature sender-G81 Interruption/Short to B+ 16581 P0197 Engine Oil Temperature Circuit Low Input 16582 P0198 Engine Oil Temperature Circuit High Input 16585 P0201 Cyl.1, Injector Circuit Fault in electrical circuit 16586 P0202 Cyl.2, Injector Circuit Fault in electrical circuit 16587 P0203 Cyl.3, Injector Circuit Fault in electrical circuit 16588 P0204 Cyl.4, Injector Circuit Fault in electrical circuit 16589 P0205 Cyl.5 Injector Circuit Fault in electrical circuit 16590 P0206 Cyl.6 Injector Circuit Fault in electrical circuit 16591 P0207 Cyl.7 Injector Circuit Fault in electrical circuit 16592 P0208 Cyl.8 Injector Circuit Fault in electrical circuit 16599 P0215 Engine Shut-Off Solenoid Malfunction 16600 P0216 Injector/Injection Timing Control Malfunction 16603 P0219 Engine Overspeed Condition 16605 P0221 Throttle Pos. Sensor -B- Circuit Range/Performance 16606 P0222 Throttle Pos. Sensor -B- Circuit Low Input 16607 P0223 Throttle Pos. Sensor -B- Circuit High Input 16609 P0225 Throttle Pos. Sensor -C- Circuit Voltage supply 16610 P0226 Throttle Pos. Sensor -C- Circuit Range/Performance 16611 P0227 Throttle Pos. Sensor -C- Circuit Low Input 16612 P0228 Throttle Pos. Sensor -C- Circuit Hight Input 16614 P0230 Fuel Pump Primary Circuit Fault in electrical circuit 16618 P0234 Turbocharger Overboost Condition Control limit exceeded 16619 P0235 Turbocharger Boost Sensor (A) Circ Control limit not reached 16620 P0236 Turbocharger Boost Sensor (A) Circ Range/Performance 16621 P0237 Turbocharger Boost Sensor (A) Circ Low Input 16622 P0238 Turbocharger Boost Sensor (A) Circ High Input 16627 P0243 Turbocharger Wastegate Solenoid (A) Open/Short Circuit to Ground 16629 P0245 Turbocharger Wastegate Solenoid (A) Low Input/Short to ground 16630 P0246 Turbocharger Wastegate Solenoid (A) High Input/Short to B+ 16636 P0252 Injection Pump Metering Control (A) Range/Performance 16645 P0261 Cyl.1 Injector Circuit Low Input/Short to ground 16646 P0262 Cyl.1 Injector Circuit High Input/Short to B+ 16648 P0264 Cyl.2 Injector Circuit Low Input/Short to ground 16649 P0265 Cyl.2 Injector Circuit High Input/Short to B+ 16651 P0267 Cyl.3 Injector Circuit Low Input/Short to ground 16652 P0268 Cyl.3 Injector Circuit High Input/Short to B+ 16654 P0270 Cyl.4 Injector Circuit Low Input/Short to ground 16655 P0271 Cyl.4 Injector Circuit High Input/Short to B+ 16657 P0273 Cyl.5 Injector Circuit Low Input/Short to ground 16658 P0274 Cyl.5 Injector Circuit High Input/Short to B+ 16660 P0276 Cyl.6 Injector Circuit Low Input/Short to ground 16661 P0277 Cyl.6 Injector Circuit High Input/Short to B+ 16663 P0279 Cyl.7 Injector Circuit Low Input/Short to ground 16664 P0280 Cyl.7 Injector Circuit High Input/Short to B+ 16666 P0282 Cyl.8 Injector Circuit Low Input/Short to ground 16667 P0283 Cyl.8 Injector Circuit High Input/Short to B+ 16684 P0300 Random/Multiple Cylinder Misfire Detected 16685 P0301 Cyl.1 Misfire Detected 16686 P0302 Cyl.2 Misfire Detected 16687 P0303 Cyl.3 Misfire Detected 16688 P0304 Cyl.4 Misfire Detected 16689 P0305 Cyl.5 Misfire Detected 16690 P0306 Cyl.6 Misfire Detected 16691 P0307 Cyl.7 Misfire Detected 16692 P0308 Cyl.8 Misfire Detected 16697 P0313 Misfire Detected Low Fuel Level 16698 P0314 Single Cylinder Misfire 16705 P0321 Ign./Distributor Eng.Speed Inp.Circ Range/Performance 16706 P0322 Ign./Distributor Eng.Speed Inp.Circ No Signal 16709 P0325 Knock Sensor 1 Circuit Electrical Fault in Circuit 16710 P0326 Knock Sensor 1 Circuit Range/Performance 16711 P0327 Knock Sensor 1 Circ Low Input 16712 P0328 Knock Sensor 1 Circ High Input 16716 P0332 Knock Sensor 2 Circ Low Input 16717 P0333 Knock Sensor 2 Circ High Input 16719 P0335 Crankshaft Pos. Sensor (A) Circ Malfunction 16720 P0336 Crankshaft Pos. Sensor (A) Circ Range/Performance/Missing tooth 16721 P0337 Crankshaft Pos.Sensor (A) Circ Low Input 16724 P0340 Camshaft Pos. Sensor (A) Circ Incorrect allocation 16725 P0341 Camshaft Pos.Sensor Circ Range/Performance 16726 P0342 Camshaft Pos.Sensor Circ Low Input 16727 P0343 Camshaft Pos.Sensor Circ High Input 16735 P0351 Ignition Coil (A) Cyl.1 Prim./Sec. Circ Malfunction 16736 P0352 Ignition Coil (B) Cyl.2 Prim./Sec. Circ Malfunction 16737 P0353 Ignition Coil (C) Cyl.3 Prim./Sec. Circ Malfunction 16738 P0354 Ignition Coil (D) Cyl.4 Prim./Sec. Circ Malfunction 16739 P0355 Ignition Coil (E) Cyl.5 Prim./Sec. Circ Malfunction 16740 P0356 Ignition Coil (F) Cyl.6 Prim./Sec. Circ Malfunction 16741 P0357 Ignition Coil (G) Cyl.7 Prim./Sec. Circ Malfunction 16742 P0358 Ignition Coil (H) Cyl.8 Prim./Sec. Circ Malfunction 16764 P0380 Glow Plug/Heater Circuit (A) Electrical Fault in Circuit 16784 P0400 Exhaust Gas Recirc.Flow Malfunction 16785 P0401 Exhaust Gas Recirc.Flow Insufficient Detected 16786 P0402 Exhaust Gas Recirc.Flow Excessive Detected 16787 P0403 Exhaust Gas Recirc. Contr. Circ Malfunction 16788 P0404 Exhaust Gas Recirc. Contr. Circ Range/Performance 16789 P0405 Exhaust Gas Recirc. Sensor (A) Circ Low Input 16790 P0406 Exhaust Gas Recirc. Sensor (A) Circ High Input 16791 P0407 Exhaust Gas Recirc. Sensor (B) Circ Low Input 16792 P0408 Exhaust Gas Recirc. Sensor (B) Circ High Input 16794 P0410 Sec.Air Inj.Sys Malfunction 16795 P0411 Sec.Air Inj.Sys. Incorrect Flow Detected 16796 P0412 Sec.Air Inj.Sys.Switching Valve A Circ Malfunction 16802 P0418 Sec. Air Inj. Sys. Relay (A) Contr. Circ Malfunction 16804 P0420 Catalyst System,Bank1 Efficiency Below Threshold 16806 P0422 Main Catalyst,Bank1 Below Threshold 16811 P0427 Catalyst Temperature Sensor, Bank 1 Low Input/Short to ground 16812 P0428 Catalyst Temperature Sensor, Bank 1 High Input/Open/Short Circuit to B+ 16816 P0432 Main Catalyst,Bank2 Efficiency Below Threshold 16820 P0436 Catalyst Temperature Sensor, Bank 2 Range/Performance 16821 P0437 Catalyst Temperature Sensor, Bank 2 Low Input/Short to ground 16822 P0438 Catalyst Temperature Sensor, Bank 2 High Input/Open/Short Circuit to B+ 16824 P0440 EVAP Emission Contr.Sys. Malfunction 16825 P0441 EVAP Emission Contr.Sys.Incorrect Purge Flow 16826 P0442 EVAP Emission Contr.Sys.(Small Leak) Leak Detected 16827 P0443 EVAP Emiss. Contr. Sys. Purge Valve Circ Electrical Fault in Circuit 16836 P0452 EVAP Emission Contr.Sys.Press.Sensor Low Input 16837 P0453 EVAP Emission Contr.Sys.Press.Sensor High Input 16839 P0455 EVAP Emission Contr.Sys.(Gross Leak) Leak Detected 16845 P0461 Fuel Level Sensor Circ Range/Performance 16846 P0462 Fuel Level Sensor Circuit Low Input 16847 P0463 Fuel Level Sensor Circuit High Input 16885 P0501 Vehicle Speed Sensor Range/Performance 16887 P0503 Vehicle Speed Sensor Intermittent/Erratic/High Input 16889 P0505 Idle Control System Malfunction 16890 P0506 Idle Control System RPM Lower than Expected 16891 P0507 Idle Control System Higher than Expected 16894 P0510 Closed Throttle Pos.Switch Malfunction 16915 P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance 16916 P0532 A/C Refrigerant Pressure Sensor Circuit Low Input 16917 P0533 A/C Refrigerant Pressure Sensor Circuit High Input 16935 P0551 Power Steering Pressure Sensor Circuit Range/Performance 16944 P0560 System Voltage Malfunction 16946 P0562 System Voltage Low Voltage 16947 P0563 System Voltage High Voltage 16952 P0568 Cruise Control Set Signal Incorrect Signal 16955 P0571 Cruise/Brake Switch (A) Circ Malfunction 16984 P0600 Serial Comm. Link (Data Bus) Message Missing 16985 P0601 Internal Contr.Module Memory Check Sum Error 16986 P0602 Control Module Programming Error/Malfunction 16987 P0603 Internal Contr.Module (KAM) Error 16988 P0604 Internal Contr.Module Random Access Memory (RAM) Error 16989 P0605 Internal Contr.Module ROM Test Error 16990 P0606 ECM/PCM Processor 17026 P0642 Knock Control Control Module Malfunction 17029 P0645 A/C Clutch Relay Control Circuit 17034 P0650 MIL Control Circuit Electrical Fault in Circuit 17038 P0654 Engine RPM Output Circuit Electrical Fault in Circuit 17040 P0656 Fuel Level Output Circuit Electrical Fault in Circuit 17084 P0700 Transm.Contr.System Malfunction 17086 P0702 Transm.Contr.System Electrical 17087 P0703 Torque Converter/Brake Switch B Circ Malfunction 17089 P0705 Transm.Range Sensor Circ.(PRNDL Inp.) Malfunction 17090 P0706 Transm.Range Sensor Circ Range/Performance 17091 P0707 Transm.Range Sensor Circ Low Input 17092 P0708 Transm.Range Sensor Circ High Input 17094 P0710 Transm.Fluid Temp.Sensor Circ. Malfunction 17095 P0711 Transm.Fluid Temp.Sensor Circ. Range/Performance 17096 P0712 Transm.Fluid Temp.Sensor Circ. Low Input 17097 P0713 Transm.Fluid Temp.Sensor Circ. High Input 17099 P0715 Input Turbine/Speed Sensor Circ. Malfunction 17100 P0716 Input Turbine/Speed Sensor Circ. Range/Performance 17101 P0717 Input Turbine/Speed Sensor Circ. No Signal 17105 P0721 Output Speed Sensor Circ Range/Performance 17106 P0722 Output Speed Sensor Circ No Signal 17109 P0725 Engine Speed Inp.Circ. Malfunction 17110 P0726 Engine Speed Inp.Circ. Range/Performance 17111 P0727 Engine Speed Inp.Circ. No Signal 17114 P0730 Gear Incorrect Ratio 17115 P0731 Gear 1 Incorrect Ratio 17116 P0732 Gear 2 Incorrect Ratio 17117 P0733 Gear 3 Incorrect Ratio 17118 P0734 Gear 4 Incorrect Ratio 17119 P0735 Gear 5 Incorrect Ratio 17124 P0740 Torque Converter Clutch Circ Malfunction 17125 P0741 Torque Converter Clutch Circ Performance or Stuck Off 17132 P0748 Pressure Contr.Solenoid Electrical 17134 P0750 Shift Solenoid A malfunction 17135 P0751 Shift Solenoid A Performance or Stuck Off 17136 P0752 Shift Solenoid A Stuck On 17137 P0753 Shift Solenoid A Electrical 17140 P0756 Shift Solenoid B Performance or Stuck Off 17141 P0757 Shift Solenoid B Stuck On 17142 P0758 Shift Solenoid B Electrical 17145 P0761 Shift Solenoid C Performance or Stuck Off 17146 P0762 Shift Solenoid C Stuck On 17147 P0763 Shift Solenoid C Electrical 17152 P0768 Shift Solenoid D Electrical 17157 P0773 Shift Solenoid E Electrical 17174 P0790 Normal/Performance Switch Circ Malfunction 17509 P1101 O2 Sensor Circ.,Bank1-Sensor1Voltage too Low/Air Leak 17510 P1102 O2 Sensor Heating Circ.,Bank1-Sensor1 Short to B+ 17511 P1103 O2 Sensor Heating Circ.,Bank1-Sensor1 Output too Low 17512 P1104 Bank1-Sensor2 Voltage too Low/Air Leak 17513 P1105 O2 Sensor Heating Circ.,Bank1-Sensor2 Short to B+ 17514 P1106 O2 Sensor Circ.,Bank2-Sensor1 Voltage too Low/Air Leak 17515 P1107 O2 Sensor Heating Circ.,Bank2-Sensor1 Short to B+ 17516 P1108 O2 Sensor Heating Circ.,Bank2-Sensor1 Output too Low 17517 P1109 O2 Sensor Circ.,Bank2-Sensor2 Voltage too Low/Air Leak 17518 P1110 O2 Sensor Heating Circ.,Bank2-Sensor2 Short to B+ 17519 P1111 O2 Control (Bank 1) System too lean 17520 P1112 O2 Control (Bank 1) System too rich 17521 P1113 Bank1-Sensor1 Internal Resistance too High 17522 P1114 Bank1-Sensor2 Internal Resistant too High 17523 P1115 O2 Sensor Heater Circ.,Bank1-Sensor1 Short to Ground 17524 P1116 O2 Sensor Heater Circ.,Bank1-Sensor1 Open 17525 P1117 O2 Sensor Heater Circ.,Bank1-Sensor2 Short to Ground 17526 P1118 O2 Sensor Heater Circ.,Bank1-Sensor2 Open 17527 P1119 O2 Sensor Heater Circ.,Bank2-Sensor1 Short to Ground 17528 P1120 O2 Sensor Heater Circ.,Bank2-Sensor1 Open 17529 P1121 O2 Sensor Heater Circ.,Bank2-Sensor2 Short to Ground 17530 P1122 O2 Sensor Heater Circ.,Bank2-Sensor2 Open 17531 P1123 Long Term Fuel Trim Add.Air.,Bank1 System too Rich 17532 P1124 Long Term Fuel Trim Add.Air.,Bank1 System too Lean 17533 P1125 Long Term Fuel Trim Add.Air.,Bank2 System too Rich 17534 P1126 Long Term Fuel Trim Add.Air.,Bank2 System too Lean 17535 P1127 Long Term Fuel Trim mult.,Bank1 System too Rich 17536 P1128 Long Term Fuel Trim mult.,Bank1 System too Lean 17537 P1129 Long Term Fuel Trim mult.,Bank2 System too Rich 17538 P1130 Long Term Fuel Trim mult.,Bank2 System too Lean 17539 P1131 Bank2-Sensor1 Internal Rsistance too High 17540 P1132 O2 Sensor Heating Circ.,Bank1+2-Sensor1 Short to B+ 17541 P1133 O2 Sensor Heating Circ.,Bank1+2-Sensor1 Electrical Malfunction 17542 P1134 O2 Sensor Heating Circ.,Bank1+2-Sensor2 Short to B+ 17543 P1135 O2 Sensor Heating Circ.,Bank1+2-Sensor2 Electrical Malfunction 17544 P1136 Long Term Fuel Trim Add.Fuel,Bank1 System too Lean 17545 P1137 Long Term Fuel Trim Add.Fuel,Bank1 System too Rich 17546 P1138 Long Term Fuel Trim Add.Fuel,Bank2 System too Lean 17547 P1139 Long Term Fuel Trim Add.Fuel,Bank2 System too Rich 17548 P1140 Bank2-Sensor2 Internal Resistance too High 17549 P1141 Load Calculation Cross Check Range/Performance 17550 P1142 Load Calculation Cross Check Lower Limit Exceeded 17551 P1143 Load Calculation Cross Check Upper Limit Exceeded 17552 P1144 Mass or Volume Air Flow Circ Open/Short to Ground 17553 P1145 Mass or Volume Air Flow Circ Short to B+ 17554 P1146 Mass or Volume Air Flow Circ Supply Malfunction 17555 P1147 O2 Control (Bank 2) System too lean 17556 P1148 O2 Control (Bank 2) System too rich 17557 P1149 O2 Control (Bank 1) Out of range 17558 P1150 O2 Control (Bank 2) Out of range 17559 P1151 Bank1, Long Term Fuel Trim, Range 1 Leanness Lower Limit Exceeded 17560 P1152 Bank1, Long Term Fuel Trim, Range 2 Leanness Lower Limit Exceeded 17562 P1154 Manifold Switch Over Malfunction 17563 P1155 Manifold Abs.Pressure Sensor Circ. Short to B+ 17564 P1156 Manifold Abs.Pressure Sensor Circ. Open/Short to Ground 17565 P1157 Manifold Abs.Pressure Sensor Circ. Power Supply Malfunction 17566 P1158 Manifold Abs.Pressure Sensor Circ. Range/Performance 17568 P1160 Manifold Temp.Sensor Circ. Short to Ground 17569 P1161 Manifold Temp.Sensor Circ. Open/Short to B+ 17570 P1162 Fuel Temp.Sensor Circ. Short to Ground 17571 P1163 Fuel Temp.Sensor Circ. Open/Short to B+ 17572 P1164 Fuel Temperature Sensor Range/Performance/Incorrect Signal 17573 P1165 Bank1, Long Term Fuel Trim, Range 1 Rich Limit Exceeded 17574 P1166 Bank1, Long Term Fuel Trim, Range 2 Rich Limit Exceeded 17579 P1171 Throttle Actuation Potentiometer Sign.2 Range/Performance 17580 P1172 Throttle Actuation Potentiometer Sign.2 Signal too Low 17581 P1173 Throttle Actuation Potentiometer Sign.2 Signal too High 17582 P1174 Fuel Trim, Bank 1 Different injection times 17584 P1176 O2 Correction Behind Catalyst,B1 Limit Attained 17585 P1177 O2 Correction Behind Catalyst,B2 Limit Attained 17586 P1178 Linear 02 Sensor / Pump Current Open Circuit 17587 P1179 Linear 02 Sensor / Pump Current Short to ground 17588 P1180 Linear 02 Sensor / Pump Current Short to B+ 17589 P1181 Linear 02 Sensor / Reference Voltage Open Circuit 17590 P1182 Linear 02 Sensor / Reference Voltage Short to ground 17591 P1183 Linear 02 Sensor / Reference Voltage Short to B+ 17592 P1184 Linear 02 Sensor / Common Ground Wire Open Circuit 17593 P1185 Linear 02 Sensor / Common Ground Wire Short to ground 17594 P1186 Linear 02 Sensor / Common Ground Wire Short to B+ 17595 P1187 Linear 02 Sensor / Compens. Resistor Open Circuit 17596 P1188 Linear 02 Sensor / Compens. Resistor Short to ground 17597 P1189 Linear 02 Sensor / Compens. Resistor Short to B+ 17598 P1190 Linear 02 Sensor / Reference Voltage Incorrect Signal 17604 P1196 O2 Sensor Heater Circ.,Bank1-Sensor1 Electrical Malfunction 17605 P1197 O2 Sensor Heater Circ.,Bank2-Sensor1 Electrical Malfunction 17606 P1198 O2 Sensor Heater Circ.,Bank1-Sensor2 Electrical Malfunction 17607 P1199 O2 Sensor Heater Circ.,Bank2-Sensor2 Electrical Malfunction 17609 P1201 Cyl.1-Fuel Inj.Circ. Electrical Malfunction 17610 P1202 Cyl.2-Fuel Inj.Circ. Electrical Malfunction 17611 P1203 Cyl.3-Fuel Inj.Circ. Electrical Malfunction 17612 P1204 Cyl.4-Fuel Inj.Circ. Electrical Malfunction 17613 P1205 Cyl.5-Fuel Inj.Circ. Electrical Malfunction 17614 P1206 Cyl.6-Fuel Inj.Circ. Electrical Malfunction 17615 P1207 Cyl.7-Fuel Inj.Circ. Electrical Malfunction 17616 P1208 Cyl.8-Fuel Inj.Circ. Electrical Malfunction 17617 P1209 Intake valves for cylinder shut-off Short circuit to ground 17618 P1210 Intake valves for cylinder shut-off Short to B+ 17619 P1211 Intake valves for cylinder shut-off Open circuit 17621 P1213 Cyl.1-Fuel Inj.Circ. Short to B+ 17622 P1214 Cyl.2-Fuel Inj.Circ. Short to B+ 17623 P1215 Cyl.3-Fuel Inj.Circ. Short to B+ 17624 P1216 Cyl.4-Fuel Inj.Circ. Short to B+ 17625 P1217 Cyl.5-Fuel Inj.Circ. Short to B+ 17626 P1218 Cyl.6-Fuel Inj.Circ. Short to B+ 17627 P1219 Cyl.7-Fuel Inj.Circ. Short to B+ 17628 P1220 Cyl.8-Fuel Inj.Circ. Short to B+ 17629 P1221 Cylinder shut-off exhaust valves Short circuit to ground 17630 P1222 Cylinder shut-off exhaust valves Short to B+ 17631 P1223 Cylinder shut-off exhaust valves Open circuit 17633 P1225 Cyl.1-Fuel Inj.Circ. Short to Ground 17634 P1226 Cyl.2-Fuel Inj.Circ. Short to Ground 17635 P1227 Cyl.3-Fuel Inj.Circ. Short to Ground 17636 P1228 Cyl.4-Fuel Inj.Circ. Short to Ground 17637 P1229 Cyl.5-Fuel Inj.Circ. Short to Ground 17638 P1230 Cyl.6-Fuel Inj.Circ. Short to Ground 17639 P1231 Cyl.7-Fuel Inj.Circ. Short to Ground 17640 P1232 Cyl.8-Fuel Inj.Circ. Short to Ground 17645 P1237 Cyl.1-Fuel Inj.Circ. Open Circ. 17646 P1238 Cyl.2-Fuel Inj.Circ. Open Circ. 17647 P1239 Cyl.3-Fuel Inj.Circ. Open Circ. 17648 P1240 Cyl.4-Fuel Inj.Circ. Open Circ. 17649 P1241 Cyl.5-Fuel Inj.Circ. Open Circ. 17650 P1242 Cyl.6-Fuel Inj.Circ. Open Circ. 17651 P1243 Cyl.7-Fuel Inj.Circ. Open Circ. 17652 P1244 Cyl.8-Fuel Inj.Circ. Open Circ. 17653 P1245 Needle Lift Sensor Circ. Short to Ground 17654 P1246 Needle Lift Sensor Circ. Range/Performance 17655 P1247 Needle Lift Sensor Circ. Open/Short to B+ 17656 P1248 Injection Start Control Deviation 17657 P1249 Fuel consumption signal Electrical Fault in Circuit 17658 P1250 Fuel Level Too Low 17659 P1251 Start of Injection Solenoid Circ Short to B+ 17660 P1252 Start of Injection Solenoid Circ Open/Short to Ground 17661 P1253 Fuel consumption signal Short to ground 17662 P1254 Fuel consumption signal Short to B+ 17663 P1255 Engine Coolant Temp.Circ Short to Ground 17664 P1256 Engine Coolant Temp.Circ Open/Short to B+ 17665 P1257 Engine Coolant System Valve Open 17666 P1258 Engine Coolant System Valve Short to B+ 17667 P1259 Engine Coolant System Valve Short to Ground 17688 P1280 Fuel Inj.Air Contr.Valve Circ. Flow too Low 17691 P1283 Fuel Inj.Air Contr.Valve Circ. Electrical Malfunction 17692 P1284 Fuel Inj.Air Contr.Valve Circ. Open 17693 P1285 Fuel Inj.Air Contr.Valve Circ. Short to Ground 17694 P1286 Fuel Inj.Air Contr.Valve Circ. Short to B+ 17695 P1287 Turbocharger bypass valve open 17696 P1288 Turbocharger bypass valve short to B+ 17697 P1289 Turbocharger bypass valve short to ground 17704 P1296 Cooling system malfunction 17705 P1297 Connection turbocharger - throttle valve pressure hose 17708 P1300 Misfire detected Reason: Fuel level too low 17721 P1319 Knock Sensor 1 Circ. Short to Ground 17728 P1320 Knock Sensor 2 Circ. Short to Ground 17729 P1321 Knock Sensor 3 Circ. Low Input 17730 P1322 Knock Sensor 3 Circ. High Input 17731 P1323 Knock Sensor 4 Circ. Low Input 17732 P1324 Knock Sensor 4 Circ. High Input 17733 P1325 Cyl.1-Knock Contr. Limit Attained 17734 P1326 Cyl.2-Knock Contr. Limit Attained 17735 P1327 Cyl.3-Knock Contr. Limit Attained 17736 P1328 Cyl.4-Knock Contr. Limit Attained 17737 P1329 Cyl.5-Knock Contr. Limit Attained 17738 P1330 Cyl.6-Knock Contr. Limit Attained 17739 P1331 Cyl.7-Knock Contr. Limit Attained 17740 P1332 Cyl.8-Knock Contr. Limit Attained 17743 P1335 Engine Torque Monitoring 2 Control Limint Exceeded 17744 P1336 Engine Torque Monitoring Adaptation at limit 17745 P1337 Camshaft Pos.Sensor,Bank1 Short to Ground 17746 P1338 Camshaft Pos.Sensor,Bank1 Open Circ./Short to B+ 17747 P1339 Crankshaft Pos./Engine Speed Sensor Cross Connected 17748 P1340 Crankshaft-/Camshaft Pos.Sens.Signals Out of Sequence 17749 P1341 Ignition Coil Power Output Stage 1 Short to Ground 17750 P1342 Ignition Coil Power Output Stage 1 Short to B+ 17751 P1343 Ignition Coil Power Output Stage 2 Short to Ground 17752 P1344 Ignition Coil Power Output Stage 2 Short to B+ 17753 P1345 Ignition Coil Power Output Stage 3 Short to Ground 17754 P1346 Ignition Coil Power Output Stage 3 Short to B+ 17755 P1347 Bank2,Crankshaft-/Camshaft os.Sens.Sign. Out of Sequence 17756 P1348 Ignition Coil Power Output Stage 1 Open Circuit 17757 P1349 Ignition Coil Power Output Stage 2 Open Circuit 17758 P1350 Ignition Coil Power Output Stage 3 Open Circuit 17762 P1354 Modulation Piston Displ.Sensor Circ. Malfunction 17763 P1355 Cyl. 1, ignition circuit Open Circuit 17764 P1356 Cyl. 1, ignition circuit Short to B+ 17765 P1357 Cyl. 1, ignition circuit Short to ground 17766 P1358 Cyl. 2, ignition circuit Open Circuit 17767 P1359 Cyl. 2, ignition circuit Short Circuit to B+ 17768 P1360 Cyl. 2, ignition circuit Short Circuit to Ground 17769 P1361 Cyl. 3, ignition circuit Open Circuit 17770 P1362 Cyl. 3, ignition circuit Short Circuit to B+ 17771 P1363 Cyl. 3, ignition circuit Short Circuit to ground 17772 P1364 Cyl. 4 ignition circuit Open Circuit 17773 P1365 Cyl. 4 ignition circuit Short circuit to B+ 17774 P1366 Cyl. 4 ignition circuit Short circuit to ground 17775 P1367 Cyl. 5, ignition circuit Open Circuit 17776 P1368 Cyl. 5, ignition circuit Short Circuit to B+ 17777 P1369 Cyl. 5, ignition circuit short to ground 17778 P1370 Cyl. 6, ignition circuit Open Circuit 17779 P1371 Cyl. 6, ignition circuit Short Circuit to B+ 17780 P1372 Cyl. 6, ignition circuit short to ground 17781 P1373 Cyl. 7, ignition circuit Open Circuit 17782 P1374 Cyl. 7, ignition circuit Short Circuit to B+ 17783 P1375 Cyl. 7, ignition circuit short to ground 17784 P1376 Cyl. 8, ignition circuit Open Circuit 17785 P1377 Cyl. 8, ignition circuit Short Circuit to B+ 17786 P1378 Cyl. 8, ignition circuit short to ground 17794 P1386 Internal Control Module Knock Control Circ.Error 17795 P1387 Internal Contr. Module altitude sensor error 17796 P1388 Internal Contr. Module drive by wire error 17799 P1391 Camshaft Pos.Sensor,Bank2 Short to Ground 17800 P1392 Camshaft Pos.Sensor,Bank2 Open Circ./Short to B+ 17801 P1393 Ignition Coil Power Output Stage 1 Electrical Malfunction 17802 P1394 Ignition Coil Power Output Stage 2 Electrical Malfunction 17803 P1395 Ignition Coil Power Output Stage 3 Electrical Malfunction 17804 P1396 Engine Speed Sensor Missing Tooth 17805 P1397 Engine speed wheel Adaptation limit reached 17806 P1398 Engine RPM signal, TD Short to ground 17807 P1399 Engine RPM signal, TD Short Circuit to B+ 17808 P1400 EGR Valve Circ Electrical Malfunction 17809 P1401 EGR Valve Circ Short to Ground 17810 P1402 EGR Valve Circ Short to B+ 17811 P1403 EGR Flow Deviation 17812 P1404 EGR Flow Basic Setting not carried out 17814 P1406 EGR Temp.Sensor Range/Performance 17815 P1407 EGR Temp.Sensor Signal too Low 17816 P1408 EGR Temp.Sensor Signal too High 17817 P1409 Tank Ventilation Valve Circ. Electrical Malfunction 17818 P1410 Tank Ventilation Valve Circ. Short to B+ 17819 P1411 Sec.Air Inj.Sys.,Bank2 Flow too Flow 17820 P1412 EGR Different.Pressure Sensor Signal too Low 17821 P1413 EGR Different.Pressure Sensor Signal too High 17822 P1414 Sec.Air Inj.Sys.,Bank2 Leak Detected 17825 P1417 Fuel Level Sensor Circ Signal too Low 17826 P1418 Fuel Level Sensor Circ Signal too High 17828 P1420 Sec.Air Inj.Valve Circ Electrical Malfunction 17829 P1421 Sec.Air Inj.Valve Circ Short to Ground 17830 P1422 Sec.Air Inj.Sys.Contr.Valve Circ Short to B+ 17831 P1423 Sec.Air Inj.Sys.,Bank1 Flow too Low 17832 P1424 Sec.Air Inj.Sys.,Bank1 Leak Detected 17833 P1425 Tank Vent.Valve Short to Ground 17834 P1426 Tank Vent.Valve Open 17840 P1432 Sec.Air Inj.Valve Open 17841 P1433 Sec.Air Inj.Sys.Pump Relay Circ. open 17842 P1434 Sec.Air Inj.Sys.Pump Relay Circ. Short to B+ 17843 P1435 Sec.Air Inj.Sys.Pump Relay Circ. Short to ground 17844 P1436 Sec.Air Inj.Sys.Pump Relay Circ. Electrical Malfunction 17847 P1439 EGR Potentiometer Error in Basic Seting 17848 P1440 EGR Valve Power Stage Open 17849 P1441 EGR Valve Circ Open/Short to Ground 17850 P1442 EGR Valve Position Sensor Signal too high 17851 P1443 EGR Valve Position Sensor Signal too low 17852 P1444 EGR Valve Position Sensor range/performance 17853 P1445 Catalyst Temp.Sensor 2 Circ. Range/Performance 17854 P1446 Catalyst Temp.Circ Short to Ground 17855 P1447 Catalyst Temp.Circ Open/Short to B+ 17856 P1448 Catalyst Temp.Sensor 2 Circ. Short to Ground 17857 P1449 Catalyst Temp.Sensor 2 Circ. Open/Short to B+ 17858 P1450 Sec.Air Inj.Sys.Circ Short to B+ 17859 P1451 Sec.Air Inj.Sys.Circ Short to Ground 17860 P1452 Sec.Air Inj.Sys. Open Circ. 17861 P1453 Exhaust gas temperature sensor 1 open/short to B+ 17862 P1454 Exhaust gas temperature sensor short 1 to ground 17863 P1455 Exhaust gas temperature sensor 1 range/performance 17864 P1456 Exhaust gas temperature control bank 1 limit attained 17865 P1457 Exhaust gas temperature sensor 2 open/short to B+ 17866 P1458 Exhaust gas temperature sensor 2 short to ground 17867 P1459 Exhaust gas temperature sensor 2 range/performance 17868 P1460 Exhaust gas temperature control bank 2 limit attained 17869 P1461 Exhaust gas temperature control bank 1 Range/Performance 17870 P1462 Exhaust gas temperature control bank 2 Range/Performance 17873 P1465 Additive Pump Short Circuit to B+ 17874 P1466 Additive Pump Open/Short to Ground 17875 P1467 EVAP Canister Purge Solenoid Valve Short Circuit to B+ 17876 P1468 EVAP Canister Purge Solenoid Valve Short Circuit to Ground 17877 P1469 EVAP Canister Purge Solenoid Valve Open Circuit 17878 P1470 EVAP Emission Contr.LDP Circ Electrical Malfunction 17879 P1471 EVAP Emission Contr.LDP Circ Short to B+ 17880 P1472 EVAP Emission Contr.LDP Circ Short to Ground 17881 P1473 EVAP Emission Contr.LDP Circ Open Circ. 17882 P1474 EVAP Canister Purge Solenoid Valve electrical malfunction 17883 P1475 EVAP Emission Contr.LDP Circ Malfunction/Signal Circ.Open 17884 P1476 EVAP Emission Contr.LDP Circ Malfunction/Insufficient Vacuum 17885 P1477 EVAP Emission Contr.LDP Circ Malfunction 17886 P1478 EVAP Emission Contr.LDP Circ Clamped Tube Detected 17908 P1500 Fuel Pump Relay Circ. Electrical Malfunction 17909 P1501 Fuel Pump Relay Circ. Short to Ground 17910 P1502 Fuel Pump Relay Circ. Short to B+ 17911 P1503 Load signal from Alternator Term. DF Range/performance/Incorrect Signal 17912 P1504 Intake Air Sys.Bypass Leak Detected 17913 P1505 Closed Throttle Pos. Does Not Close/Open Circ 17914 P1506 Closed Throttle Pos.Switch Does Not Open/Short to Ground 17915 P1507 Idle Sys.Learned Value Lower Limit Attained 17916 P1508 Idle Sys.Learned Value Upper Limit Attained 17917 P1509 Idle Air Control Circ. Electrical Malfunction 17918 P1510 Idle Air Control Circ. Short to B+ 17919 P1511 Intake Manifold Changeover Valve circuit electrical malfunction 17920 P1512 Intake Manifold Changeover Valve circuit Short to B+ 17921 P1513 Intake Manifold Changeover Valve2 circuit Short to B+ 17922 P1514 Intake Manifold Changeover Valve2 circuit Short to ground 17923 P1515 Intake Manifold Changeover Valve circuit Short to Ground 17924 P1516 Intake Manifold Changeover Valve circuit Open 17925 P1517 Main Relay Circ. Electrical Malfunction 17926 P1518 Main Relay Circ. Short to B+ 17927 P1519 Intake Camshaft Contr.,Bank1 Malfunction 17928 P1520 Intake Manifold Changeover Valve2 circuit Open 17929 P1521 Intake Manifold Changeover Valve2 circuit electrical malfunction 17930 P1522 Intake Camshaft Contr.,Bank2 Malfunction 17931 P1523 Crash Signal from Airbag Control Unit range/performance 17933 P1525 Intake Camshaft Contr.Circ.,Bank1 Electrical Malfunction 17934 P1526 Intake Camshaft Contr.Circ.,Bank1 Short to B+ 17935 P1527 Intake Camshaft Contr.Circ.,Bank1 Short to Ground 17936 P1528 Intake Camshaft Contr.Circ.,Bank1 Open 17937 P1529 Camshaft Control Circuit Short to B+ 17938 P1530 Camshaft Control Circuit Short to ground 17939 P1531 Camshaft Control Circuit open 17941 P1533 Intake Camshaft Contr.Circ.,Bank2 Electrical Malfunction 17942 P1534 Intake Camshaft Contr.Circ.,Bank2 Short to B+ 17943 P1535 Intake Camshaft Contr.Circ.,Bank2 Short to Ground 17944 P1536 Intake Camshaft Contr.Circ.,Bank2 Open 17945 P1537 Engine Shutoff Solenoid Malfunction 17946 P1538 Engine Shutoff Solenoid Open/Short to Ground 17947 P1539 Clutch Vacuum Vent Valve Switch Incorrect signal 17948 P1540 Vehicle Speed Sensor High Input 17949 P1541 Fuel Pump Relay Circ Open 17950 P1542 Throttle Actuation Potentiometer Range/Performance 17951 P1543 Throttle Actuation Potentiometer Signal too Low 17952 P1544 Throttle Actuation Potentiometer Signal too High 17953 P1545 Throttle Pos.Contr Malfunction 17954 P1546 Boost Pressure Contr.Valve Short to B+ 17955 P1547 Boost Pressure Contr.Valve Short to Ground 17956 P1548 Boost Pressure Contr.Valve Open 17957 P1549 Boost Pressure Contr.Valve Short to Ground 17958 P1550 Charge Pressure Deviation 17959 P1551 Barometric Pressure Sensor Circ. Short to B+ 17960 P1552 Barometric Pressure Sensor Circ. Open/Short to Ground 17961 P1553 Barometric/manifold pressure signal ratio out of range 17962 P1554 Idle Speed Contr.Throttle Pos. Basic Setting Conditions not met 17963 P1555 Charge Pressure Upper Limit exceeded 17964 P1556 Charge Pressure Contr. Negative Deviation 17965 P1557 Charge Pressure Contr. Positive Deviation 17966 P1558 Throttle Actuator Electrical Malfunction 17967 P1559 Idle Speed Contr.Throttle Pos. Adaptation Malfunction 17968 P1560 Maximum Engine Speed Exceeded 17969 P1561 Quantity Adjuster Deviation 17970 P1562 Quantity Adjuster Upper Limit Attained 17971 P1563 Quantity Adjuster Lower Limit Attained 17972 P1564 Idle Speed Contr.Throttle Pos. Low Voltage During Adaptation 17973 P1565 Idle Speed Control Throttle Position lower limit not attained 17974 P1566 Load signal from A/C compressor range/performance 17975 P1567 Load signal from A/C compressor no signal 17976 P1568 Idle Speed Contr.Throttle Pos. mechanical Malfunction 17977 P1569 Cruise control switch Incorrect signal 17978 P1570 Contr.Module Locked 17979 P1571 Left Eng. Mount Solenoid Valve Short to B+ 17980 P1572 Left Eng. Mount Solenoid Valve Short to ground 17981 P1573 Left Eng. Mount Solenoid Valve Open circuit 17982 P1574 Left Eng. Mount Solenoid Valve Electrical fault in circuit 17983 P1575 Right Eng. Mount Solenoid Valve Short to B+ 17984 P1576 Right Eng. Mount Solenoid Valve Short to ground 17985 P1577 Right Eng. Mount Solenoid Valve Open circuit 17986 P1578 Right Eng. Mount Solenoid Valve Electrical fault in circuit 17987 P1579 Idle Speed Contr.Throttle Pos. Adaptation not started 17988 P1580 Throttle Actuator B1 Malfunction 17989 P1581 Idle Speed Contr.Throttle Pos. Basic Setting Not Carried Out 17990 P1582 Idle Adaptation at Limit 17991 P1583 Transmission mount valves Short to B+ 17992 P1584 Transmission mount valves Short to ground 17993 P1585 Transmission mount valves Open circuit 17994 P1586 Engine mount solenoid valves Short to B+ 17995 P1587 Engine mount solenoid valves Short to ground 17996 P1588 Engine mount solenoid valves Open circuit 18008 P1600 Power Supply (B+) Terminal 15 Low Voltage 18010 P1602 Power Supply (B+) Terminal 30 Low Voltage 18011 P1603 Internal Control Module Malfunction 18012 P1604 Internal Control Module Driver Error 18013 P1605 Rough Road/Acceleration Sensor Electrical Malfunction 18014 P1606 Rough Road Spec Engine Torque ABS-ECU Electrical Malfunction 18015 P1607 Vehicle speed signal Error message from instrument cluster 18016 P1608 Steering angle signal Error message from steering angle sensor 18017 P1609 Crash shut-down activated 18019 P1611 MIL Call-up Circ./Transm.Contr.Module Short to Ground 18020 P1612 Electronic Control Module Incorrect Coding 18021 P1613 MIL Call-up Circ Open/Short to B+ 18022 P1614 MIL Call-up Circ./Transm.Contr.Module Range/Performance 18023 P1615 Engine Oil Temperature Sensor Circuit range/performance 18024 P1616 Glow Plug/Heater Indicator Circ. Short to B+ 18025 P1617 Glow Plug/Heater Indicator Circ. Open/Short to Ground 18026 P1618 Glow Plug/Heater Relay Circ. Short to B+ 18027 P1619 Glow Plug/Heater Relay Circ. Open/Short to Ground 18028 P1620 Engine coolant temperature signal open/short to B+ 18029 P1621 Engine coolant temperature signal short to ground 18030 P1622 Engine coolant temperature signal range/performance 18031 P1623 Data Bus Powertrain No Communication 18032 P1624 MIL Request Sign.active 18033 P1625 Data-Bus Powertrain Unplausible Message from Transm.Contr. 18034 P1626 Data-Bus Powertrain Missing Message from Transm.Contr. 18035 P1627 Data-Bus Powertrain missing message from fuel injection pump 18036 P1628 Data-Bus Powertrain missing message from steering sensor 18037 P1629 Data-Bus Powertrain missing message from distance control 18038 P1630 Accelera.Pedal Pos.Sensor 1 Signal too Low 18039 P1631 Accelera.Pedal Pos.Sensor 1 Signal too High 18040 P1632 Accelera.Pedal Pos.Sensor 1 Power Supply Malfunction 18041 P1633 Accelera.Pedal Pos.Sensor 2 Signal too Low 18042 P1634 Accelera.Pedal Pos.Sensor 2 Signal too High 18043 P1635 Data Bus Powertrain missing message f.air condition control 18044 P1636 Data Bus Powertrain missing message from Airbag control 18045 P1637 Data Bus Powertrain missing message f.central electr.control 18046 P1638 Data Bus Powertrain missing message from clutch control 18047 P1639 Accelera.Pedal Pos.Sensor 1+2 Range/Performance 18048 P1640 Internal Contr.Module (EEPROM) Error 18049 P1641 Please check DTC Memory of Air Condition ECU 18050 P1642 Please check DTC Memory of Airbag ECU 18051 P1643 Please check DTC Memory of central electric ECU 18052 P1644 Please check DTC Memory of clutch ECU 18053 P1645 Data Bus Powertrain missing message f.all wheel drive contr. 18054 P1646 Please Check DTC Memory of all wheel drive ECU 18055 P1647 Please check coding of ECUs in Data Bus Powertrain 18056 P1648 Data Bus Powertrain Malfunction 18057 P1649 Data Bus Powertrain Missing message from ABS Control Module 18058 P1650 Data Bus Powertrain Missing message fr.instrument panel ECU 18059 P1651 Data Bus Powertrain missing messages 18060 P1652 Please check DTC Memory of transmission ECU 18061 P1653 Please check DTC Memory of ABS Control Module 18062 P1654 Please check DTC Memory of control panel ECU 18063 P1655 Please check DTC Memory of ADR Control Module 18064 P1656 A/C clutch relay circuit short to ground 18065 P1657 A/C clutch relay circuit short to B+ 18066 P1658 Data Bus Powertrain Incorrect signal from ADR Control Module 18084 P1676 Drive by Wire-MIL Circ. Electrical Malfunction 18085 P1677 Drive by Wire-MIL Circ. Short to B+ 18086 P1678 Drive by Wire-MIL Circ. Short to Ground 18087 P1679 Drive by Wire-MIL Circ. Open 18089 P1681 Contr.Unit Programming, Programming not Finished 18092 P1684 Contr.Unit Programming Communication Error 18094 P1686 Contr.Unit Error Programming Error 18098 P1690 Malfunction Indication Light Malfunction 18099 P1691 Malfunction Indication Light Open 18100 P1692 Malfunction Indication Light Short to Ground 18101 P1693 Malfunction Indication Light Short to B+ 18102 P1694 Malfunction Indication Light Open/Short to Ground 18112 P1704 Kick Down Switch Malfunction 18113 P1705 Gear/Ratio Monitoring Adaptation limit reached 18119 P1711 Wheel Speed Signal 1 Range/Performance 18124 P1716 Wheel Speed Signal 2 Range/Performance 18129 P1721 Wheel Speed Signal 3 Range/Performance 18131 P1723 Starter Interlock Circ. Open 18132 P1724 Starter Interlock Circ. Short to Ground 18134 P1726 Wheel Speed Signal 4 Range/Performance 18136 P1728 Different Wheel Speed Signals Range/Performance 18137 P1729 Starter Interlock Circ. Short to B+ 18141 P1733 Tiptronic Switch Down Circ. Short to Ground 18147 P1739 Tiptronic Switch up Circ. Short to Ground 18148 P1740 Clutch temperature control 18149 P1741 Clutch pressure adaptation at limit 18150 P1742 Clutch torque adaptation at limit 18151 P1743 Clutch slip control signal too high 18152 P1744 Tiptronic Switch Recognition Circ. Short to Ground 18153 P1745 Transm.Contr.Unit Relay Short to B+ 18154 P1746 Transm.Contr.Unit Relay Malfunction 18155 P1747 Transm.Contr.Unit Relay Open/Short to Ground 18156 P1748 Transm.Contr.Unit Self-Check 18157 P1749 Transm.Contr.Unit Incorrect Coded 18158 P1750 Power Supply Voltage Low Voltage 18159 P1751 Power Supply Voltage High Voltage 18160 P1752 Power Supply Malfunction 18168 P1760 Shift Lock Malfunction 18169 P1761 Shift Lock Short to Ground 18170 P1762 Shift Lock Short to B+ 18171 P1763 Shift Lock Open 18172 P1764 Transmission temperature control 18173 P1765 Hydraulic Pressure Sensor 2 adaptation at limit 18174 P1766 Throttle Angle Signal Stuck Off 18175 P1767 Throttle Angle Signal Stuck On 18176 P1768 Hydraulic Pressure Sensor 2 Too High 18177 P1769 Hydraulic Pressure Sensor 2 Too Low 18178 P1770 Load Signal Range/Performance 18179 P1771 Load Signal Stuck Off 18180 P1772 Load Signal Stuck On 18181 P1773 Hydraulic Pressure Sensor 1 Too High 18182 P1774 Hydraulic Pressure Sensor 1 Too Low 18183 P1775 Hydraulic Pressure Sensor 1 adaptation at limit 18184 P1776 Hydraulic Pressure Sensor 1 range/performance 18185 P1777 Hydraulic Pressure Sensor 2 range/performance 18186 P1778 Solenoid EV7 Electrical Malfunction 18189 P1781 Engine Torque Reduction Open/Short to Ground 18190 P1782 Engine Torque Reduction Short to B+ 18192 P1784 Shift up/down Wire Open/Short to Ground 18193 P1785 Shift up/down Wire Short to B+ 18194 P1786 Reversing Light Circ. Open 18195 P1787 Reversing Light Circ. Short to Ground 18196 P1788 Reversing Light Circ. Short to B+ 18197 P1789 Idle Speed Intervention Circ. Error Message from Engine Contr. 18198 P1790 Transmission Range Display Circ. Open 18199 P1791 Transmission Range Display Circ. Short to Ground 18200 P1792 Transmission Range Display Circ. Short to B+ 18201 P1793 Output Speed Sensor 2 Circ. No Signal 18203 P1795 Vehicle Speed Signal Circ. Open 18204 P1796 Vehicle Speed Signal Circ. Short to Ground 18205 P1797 Vehicle Speed Signal Circ. Short to B+ 18206 P1798 Output Speed Sensor 2 Circ. Range/Performance 18207 P1799 Output Speed Sensor 2 Circ. Rpm too High 18221 P1813 Pressure Contr.Solenoid 1 Electrical 18222 P1814 Pressure Contr.Solenoid 1 Open/Short to Ground 18223 P1815 Pressure Contr.Solenoid 1 Short to B+ 18226 P1818 Pressure Contr.Solenoid 2 Electrical 18227 P1819 Pressure Contr.Solenoid 2 Open/Short to Ground 18228 P1820 Pressure Contr.Solenoid 2 Short to B+ 18231 P1823 Pressure Contr.Solenoid 3 Electrical 18232 P1824 Pressure Contr.Solenoid 3 Open/Short to Ground 18233 P1825 Pressure Contr.Solenoid 3 Short to B+ 18236 P1828 Pressure Contr.Solenoid 4 Electrical 18237 P1829 Pressure Contr.Solenoid 4 Open/Short to Ground 18238 P1830 Pressure Contr.Solenoid 4 Short to B+ 18242 P1834 Pressure Contr.Solenoid 5 Open/Short to Ground 18243 P1835 Pressure Contr.Solenoid 5 Short to B+ 18249 P1841 Engine/Transmission Control Modules Versions do not match 18250 P1842 Please check DTC Memory of instrument panel ECU 18251 P1843 Please check DTC Memory of ADR Control Module 18252 P1844 Please check DTC Memory of central electric control ECU 18255 P1847 Please check DTC Memory of brake system ECU 18256 P1848 Please check DTC Memory of engine ECU 18257 P1849 Please check DTC Memory of transmission ECU 18258 P1850 Data-Bus Powertrain Missing Message from Engine Contr. 18259 P1851 Data-Bus Powertrain Missing Message from Brake Contr. 18260 P1852 Data-Bus Powertrain Unplausible Message from Engine Contr. 18261 P1853 Data-Bus Powertrain Unplausible Message from Brake Contr. 18262 P1854 Data-Bus Powertrain Hardware Defective 18263 P1855 Data-Bus Powertrain Software version Contr. 18264 P1856 Throttle/Pedal Pos.Sensor A Circ. Error Message from Engine Contr. 18265 P1857 Load Signal Error Message from Engine Contr. 18266 P1858 Engine Speed Input Circ. Error Message from Engine Contr. 18267 P1859 Brake Switch Circ. Error Message from Engine Contr. 18268 P1860 Kick Down Switch Error Message from Engine Contr. 18269 P1861 Throttle Position (TP) sensor Error Message from ECM 18270 P1862 Data Bus Powertrain Missing message from instr. panel ECU 18271 P1863 Data Bus Powertrain Missing Message from St. Angle Sensor 18272 P1864 Data Bus Powertrain Missing message from ADR control module 18273 P1865 Data Bus Powertrain Missing message from central electronics 18274 P1866 Data Bus Powertrain Missing messages |
+1 make this a sticky
only problem with those codes is they don't explain the problems or give you alternative problems that could throw that code;)
True, but they do provide a foundation to start looking for problems
I searched for my problem and I got this topic. I liked it so bumb!
Also I got a code today. I Vaged my car (there is no CEL on) and got this; 17584 | P1176 | O2 Correction Behind Catalyst,B1 Limit Attained I know car was running rich but what exacly this code means ? Any ideas ? |
If its behind the cat I would ignore it... those are basically there to tell if the cat is working properly. Reset them and see if it comes back.
I dont have a cat :)
I have 3" cat delete pipe. |
