GTI almost took me!!! help!
well if you're B5 then you're most likely running a GIAC base chip for your ko4.. also could be a few other's but i doubt it. just open your ECU box and look at the sticker's and you'll know..
but you have the option to gain around 30-50hp with upgrading to a PC-16 file.. you're probably running 15ish psi now and with the PC-16 you'll be in the low 20s.. you'll also need a FMIC, and some 310cc injectors.. a testpipe wouldn't hurt either
ORIGINAL: Ericp501
And what do you think the max shot of nos i could do to the fmic would be.. and i mean safe shot maybe 1 time a month.
Couldn't i just do that myself then with some CO2 and thin copper pipe? and i'm looking into this pc-16 thing.. i'm looking on www.awe-tuning.com and i found a injector/giac chip upgrade for $200 is that about right? I mean i'll wait till spring prob and first put a fmic.. but that sounds good huh? and maybe the test pipe if worth it
ORIGINAL: khj677turbo
I have the basic file, i run 25 psi... why do you say 15?? I did that with my neuspeed suck d chip
so you are running j31
