have testpie+check engine light car is lazy?
Old Mar 27, 2007 | 02:46 PM
Sp33d07's Avatar
Default have testpie+check engine light car is lazy?
well i have a testpipe on the car with a 2.5 exhaust system all the way out . it set off the check engine light on when i put the test pipe, i am guessing its the o2 sensor. the car feels like its gonna stop running sometimes rough idles but then it goes away until i stop at a light again. anyone ran in to a problem like this and know how to fix this stiuation?? thanks guys
Old Mar 27, 2007 | 02:49 PM
new2me's Avatar
Default RE: have testpie+check engine light car is lazy?
Did you use the non-fouler's when installing the O2's?
Old Mar 27, 2007 | 10:34 PM
Sp33d07's Avatar
wow thats the first time i hear that what is the purpose or what is it?
Old Mar 27, 2007 | 11:03 PM
Lazer Viking's Avatar
they move the 02 sensor out of the mainstream.. and prevent the car from throwing a check engine light via secondary 02
search for anti-fowler mod
Old Mar 27, 2007 | 11:38 PM
onepoint8tee's Avatar
that wouldnt cause your engine to be lazy though. only the front one can be related to running issues if its bad. double check all your vacuum and boost connections around the airbox since that had to be taken out to get the test pipe in.
Old Mar 27, 2007 | 11:45 PM
x1rider's Avatar
ORIGINAL: Sp33d07
The 90 degree spacer (Wayne Schmidt from VW vortex) works well with a HFC (not sure if it works as well with a test pipe). No CEL since I installed it (I was getting CEL's just about every day).
http://www.audigeeks.com/forums/index.php?topic=2167.0
mikeysline06
Nov 4, 2010 10:32 PM
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
blanthony
Mar 25, 2006 01:18 PM
