AudiForums.com
-   Audi A4 (https://www.audiforums.com/forum/audi-a4-8/)
-   -   Head studs (https://www.audiforums.com/forum/audi-a4-8/head-studs-72665/)
theguy1084 Aug 19, 2007 11:57 AM
Head studs
Well I install my raceware head studs the other day. I did what it said to do and installed them only hand tight. I did however have an issue with one that only went in about a 1/4 of the way and then Stopped. Should I run it in the rest of the way with pliers to even it out with the rest of them? One other thing what are you guys torquing the head to with these studs. Thanks. BTW this is an engine i am building and not the one in my car.
onepoint8tee Aug 19, 2007 12:19 PM
RE: Head studs
There might be 2 people that are members here that will have the answer to your question. All I can say is that I'm a head stud
cincyTT Aug 19, 2007 12:45 PM
RE: Head studs
This needs to be posted in the 1.8t section over in vortex if you havent already. Torque specs should be in the 1.8t section faq also.
theguy1084 Aug 19, 2007 02:07 PM
RE: Head studs
Yeah I havent posted there yet just on elitedubs.com
cincyTT Aug 19, 2007 02:39 PM
RE: Head studs
alot of the vortex guys are on there also.
theguy1084 Aug 19, 2007 04:18 PM
RE: Head studs
Yeah I think elitedubs is the best ongood/correct info but its hard to get a response to you post
S obsessed Aug 19, 2007 06:53 PM
RE: Head studs
Make sure there is no fluid or gunk in hole, it will hydraulic lock and you won't be able to move stud down anymore. remove stud and clean out hole and suck out fluid. This is a common thing cause when you pull head all sorts of coolant and oil can go in dem dare holes.
theguy1084 Aug 19, 2007 08:41 PM
RE: Head studs
I know what you are saying but this is on a short block that I ordered(never had coolant or oil in it). I did everything to clean out the hole short of running in a tap to clean up the treads....I am sure I will be ok as long as its even with then others and not to deep..right???
Belligerenceā„¢ Aug 19, 2007 10:15 PM
RE: Head studs
can't hurt to take it out and run a tap through to chase the threads.
