AudiForums.com
-   Audi A4 (https://www.audiforums.com/forum/audi-a4-8/)
-   -   headlight bulb? (https://www.audiforums.com/forum/audi-a4-8/headlight-bulb-38738/)
joelml Aug 12, 2006 12:47 PM
headlight bulb?
what is a good lookin headlight bulb?
ejc317 Aug 12, 2006 01:06 PM
RE: headlight bulb?
6000k hid
tooxtreme8813 Aug 12, 2006 02:37 PM
RE: headlight bulb?
12000k HID
http://i4.photobucket.com/albums/y10...3/DSCN1697.jpg
joelml Aug 12, 2006 03:40 PM
RE: headlight bulb?
where would i need to go to get those?
2001 a4 fwd 5speed
giac
710n
smoothriderA4 Aug 13, 2006 01:50 AM
RE: headlight bulb?
ORIGINAL: ejc317
6000k hid
do you have a pic of what this looks like? those 12000ks look hot...does anyone know what the stock bulbs are for the newer audi's?
01A4T Aug 13, 2006 01:56 AM
RE: headlight bulb?
you can't just put in a bulb to have xenons. converting to 6000 or 12000k hid's requires a bit of work and a decent amount of money. if you already have projectors im assuming you have a 99.5+, the closest bulb to get the effect you want would be a silverstar or a comparable bulb.(its a simple solution without going the xenon route)
smoothriderA4 Aug 13, 2006 07:20 AM
RE: headlight bulb?
That is right, a xenon system is going to run you some money. ive heard both sides of the story of people telling me that the bulb will be3 fine, but I would go with the whole system.
Dr.S4 Aug 13, 2006 09:58 AM
RE: headlight bulb?
If u go for the Xenon use the 4300K bulb (Philips or Hella no Asian ones[:'(])and no higher than 4500K, the light output after 4500K reduces therefore to put it simply u wont light up the road at nite as well and u will get 'eye strain'.
There is a reason why Audi uses the 4300K(Philips) Xenon strait out of the factory, coz it gives the best light output: any higher is for 'show' and u will prob get pulled up with 12000K
As for halogen is prob wat u after go for the Philips NightGuide, its got the best ouput and has a slight blue tint to it as well, check out the link
http://www.nam.lighting.philips.com/...nightguide.php
I had the Philips BlueVision and then CrystalVision: but r only for looks and are not good for nite drivin[:@]: re worse light than standard
Authin Aug 13, 2006 12:57 PM
RE: headlight bulb?
I've got a 96 quattro. I need to replace my stock bulbs since one burned out. Which bulb would you say is the best for an easy swap. I do not want to spend money replacing the entire highlight system but am willing to spend some money on a good bulb for a quick and easy replacement for the stock housing. Would the NightGuide bulb work for my car without having to upgrade the housing? Thanks
01A4T Aug 13, 2006 06:07 PM
RE: headlight bulb?
to the post above....yes, the bulb will work without upgrading anything.
