Headlight Problem????
Old Oct 13, 2007 | 09:09 PM
DieHardAudiA4's Avatar
Default Headlight Problem????
i have a 98 a4 1.8t quatro 5spd, when i go to turn the headlights on they dont come on, only running lights in corner, i checked the bulbs and there good and i disconnected the wiring and reconnected and i checked the fuses and everything is still good. i think that there a either a short or a bad ground somewhere but i have no idea where to start looking, has n e one ever had this problem before? plz i need the help bc im trying to sell the car and kinda cant if the lights dont work.
Old Oct 13, 2007 | 11:14 PM
chaos92287's Avatar
Default RE: Headlight Problem????
try and flash your high beams. if they work its most likely a fuse or a switch in your steering column. there's more fuses behind your dash
so that could be it. the headlight switch- http://www.audiworld.com/tech/elec114.shtml
if neither of those works than i have no idea
a. debarros
Jun 24, 2011 11:57 PM
mdemisem
Feb 2, 2009 09:35 AM
bpguitarbiker
Aug 20, 2008 11:20 PM
paparose_12
Oct 29, 2007 10:00 PM
The Somps
Feb 18, 2007 08:10 PM
