Heads
Old Oct 21, 2007 | 07:48 PM
david45's Avatar
Default Heads
Ok, I have a 96 A4 2.8 quattro, im looking for some performance heads and I was hopeing that someone knew of some websites that has performance parts for my car, or what would you guys recomend? thanks.
Old Oct 21, 2007 | 07:54 PM
SAudi's Avatar
Default RE: Heads
Sorry mate, the 12v V6 int eh early A4's is useless for tuning, the only thing you can get that has to do with the head is Mance's camshaft, and ive been looking for then for a while. the only performance mod is the exhaust and intake, and other than that its fubar.
Old Oct 21, 2007 | 08:47 PM
operator's Avatar
Default RE: Heads
Most machine shops can do a proper port and polish on your heads to increase flow. The benifits of a port & polish ona turbo are minimal but on a natually aspirated car its usually about 10% as well as better gas milege. Ive done it to both of my previous VWs but your gona spend some cash to get it done.
Old Oct 21, 2007 | 08:51 PM
Karl's Avatar
Default RE: Heads
hell do the port and polish yourself. save yourself some money. then gasket match your exhaust manifold you might pickup +1hp
Old Oct 21, 2007 | 08:59 PM
operator's Avatar
Default RE: Heads
Def wouldnt recomend doing it yourself if you dont know what your doing (bit more than gasket matching) but yea its not a huge difference but its the same gains you get from odering aftermarket performance heads. I noticed a difference in my VW so its more than 1+hp gain.
Old Oct 21, 2007 | 09:04 PM
david45's Avatar
Default RE: Heads
lol, well if i cant put heads on it, what else could i do thats gona give at a few more ponies =D
Old Oct 21, 2007 | 09:11 PM
oneg's Avatar
Default RE: Heads
nitrous
oneg's Avatar
Default RE: Heads
s/c
oneg's Avatar
Default RE: Heads
only drive down hills
Old Oct 21, 2007 | 09:19 PM
ImTheDevil's Avatar
Default RE: Heads
I was actually gonna suggest gasket-matching the intake as well - every little bit, but like it was stated above, it's going to cost a lot, either in cash to have it done, or in time for you to do it, and the gains just aren't going to be much - probably not nearly enough to make it worth the time or expense.
