help
Old Sep 13, 2007 | 07:18 PM
JasonG2423's Avatar
Default help
so my check engine light is on and i got it checked at it read 171 and said its running lean, the guy gave me one way to see if i can fix it by cleanin the diode in my MAF sensor, and the car runs back ot stock form(APR 93 octane chip) it wont go over 7 psi and it runs very shitty
Old Sep 14, 2007 | 04:24 AM
qUaTtRoA4's Avatar
Default RE: help
just out of curiosity, are you recirculating your bov?...
sorry to hear abou the CEL... sound like you are in limp mode...
I'm sure someone will have a better Idea of what to do...
gl!
Old Sep 14, 2007 | 04:32 AM
techbod's Avatar
Default RE: help
P0171 = system too lean, bank 1 probable cause, intake/exhaust leak, AIR system, MAF sensor, fuel pressure/pump, injectors, O2 sensor.
im going for an air leak so check the vacuum pipes and AIR system for failed/split pipes
