Help again
Old Dec 2, 2007 | 07:41 PM
afour's Avatar
Default Help again
Ok im driving down the road and all of a sudden my freakin radio just dies... maybe a fuse? Anybody else have this problem?
Also I replace my rear right light and then my left goes out. Could this car have an electrical problem that i dont want?
Old Dec 2, 2007 | 07:54 PM
turbo kraut's Avatar
Tech Guru
Default RE: Help again
could be electrical.......
check your fuses... could be coincidence......
did you have a cup above the radio, that was sweating?
Old Dec 2, 2007 | 07:57 PM
afour's Avatar
anybody know where the fuse box is for the radio? *** i just bought the car and i dont have the car manual
Old Dec 2, 2007 | 08:05 PM
itsbigj05's Avatar
the fuse box is on the side of the dash on the drivers side. You have to open the driver's door to pop off the panel and all the fuses are under there. I belive the fuse for the radio is number 37, but don't take my word for it. If you bust out the old manual and look in the index for "fuses" it will give a list of all the fuses and even a picture lol.
i hope that helped and good luck.
edit.. oops i just realized you said you didnt have the manual. sorry about that.it should be a yellow 20 amp fuse at the bottom centerish.
Old Dec 2, 2007 | 08:07 PM
A4 Effort's Avatar
The radio has two fuses. One in the main fuse box located on the driver's side dash (open driver's side door). You will see the cover; simply pry it off at the bottom with a flat-tip screwdriver.
The second is on the radio itself - so you'll need the radio removal keys to pull the radioout if you don't have them already.
Old Dec 2, 2007 | 08:11 PM
itsbigj05's Avatar
i never had the radio removal tools, so i used two tiny screw drivers. Once i got it out, I never fully pushed it the whole way back in because it was such a pain to get out the first time lol.
Old Dec 2, 2007 | 08:37 PM
afour's Avatar
You guys are awesome! Ill give the main fusebox a try. I was readin on another forum that i should just pull out the fuse and put it back in. If that does not work pull out the fuse and drive around for a hr and put it back.
What is the fuse number? Will there be a a diagram on the back side of the fuse box?
Old Dec 2, 2007 | 09:03 PM
afour's Avatar
ANYONE KNOW THE FUSE #
Old Dec 2, 2007 | 10:04 PM
afour's Avatar
UPDATE! Ok went to go get some milk and my fukin radio is working again. Anyone?
