help with diverter valve
Old Oct 30, 2007 | 03:00 AM
sundevil1017's Avatar
Default help with diverter valve
i just bought a new diverter valve, and i want to install it but have no idea how...i searched but nothing came up...could someone please help me on how to install it and where the stock dv even is at? i know what it does and the different ones that exist, i just dont know where the stock one is, and i need to know how to install the new one i just bought...i tried to find pics on where it goes and how to install the new one but i found nothing i need pics on how to and where it is///[&o], help!...thanks
Old Oct 30, 2007 | 04:01 AM
khj677turbo's Avatar
Default RE: help with diverter valve
Should be lots of info, even a sticky at the top. Ive never checked it, but it should have good info. Its easy, lift the car, take off the bottom plastic thing, should be 4-6 screws that take about half to a full turn. pull that down, get under the car, about where your headlight and grill are, draw a invisible line down and slide under right there. Look up should be a good sized black pipe right infront of your eyes coming from the turbo, from there you should be able to locate your dv, its on the top side of the black piping.
http://www.awe-tuning.com/media/pdf/...tall_A4_B5.pdf
Old Oct 30, 2007 | 12:52 PM
Papachristou's Avatar
put your car on ramps/jacks (front)
remove belly pan
get under passenger side, DV is near radiator/cooling fans
1time OEM clamps are a bitch, use an L needle, if u cant break them, dremel them off
reinstall new DV, noting orientation of old one before you remove!!!
drive
Old Oct 30, 2007 | 01:28 PM
chaos92287's Avatar
everyone suggests doing it from the bottom but i did it from the top. you just gotta find a friend with little hands lol. just look down in between the pulleys and the radiator, should be down about a foot and a little on the left. if you still can't find it, follow the blue vacuum hose coming out of the intake manifold. it goes right to the dv.
here's some DIY articles
http://audizine.com/forum/showthread.php?t=17369
http://forums.vwvortex.com/zerothread?id=2192724
Connor Schleicher
Nov 8, 2011 07:13 PM
07titanium
B7 Models
Oct 25, 2011 08:11 PM
justinclink1
Aug 30, 2010 11:40 PM
07titanium
B7 Models
Mar 5, 2009 08:29 PM
FtMyersAudiFreak
May 25, 2005 11:35 PM
