Help me please
I just changed my stereo in my audi a4 tdi SE 1999 i also put in an amp and a bass box, however i realised that my key fob was not working anymore. I can manually lock my car but the red light does not flash anymore
CAN ANYONE HELP PLEASE
THANKS
THANKS
Im not sure if this works with your car.. but here it goes:
To resync your key to your car, press the unlock button on the key and then manually unlock/lock the door. This should sync them up.
Let me know if this solves your problem!
K-Line problem maybe?
My guess is you did not reconnect a wire somewhere. The stock radios in the Audis are all tied into the alarm systems. Did you use some sort of pre-made harness?
