help need with vag codes, thanx
Old Mar 19, 2005 | 12:43 AM
rnbguy's Avatar
Default help need with vag codes, thanx
i really need help my cars been bad on fuel i got vag-com of my uncle to test it and iget these error codes.. any tips are more then appreciated..
Address 01 -------------------------------------------------------
Controller: 8D0 907 557 C
Component: 1,8L R4/5V MOTR AT D07
Coding: 04031
Shop #: WSC 06335
2 Faults Found:
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-00 - -
00561 - Mixture Adaptation
14-00 - Adaptation Limit (Add) Exceeded
Readiness: N/A
I have a 1.8N/A AUDI A4 B5
Old Mar 19, 2005 | 12:57 AM
Jestnomen's Avatar
6th Gear
Default RE: help need with vag codes, thanx
I couln't find much:
http://forums.audiworld.com/a4/msgs/2007806.phtml
Old Mar 19, 2005 | 01:00 AM
rnbguy's Avatar
thanx for the reply though, appreciated.. anyone???
Old Mar 19, 2005 | 01:57 AM
Doose's Avatar
16518/P0134 is a bad O2 sensor. That will cause the fuel mixture to be off. Not sure what year you are, I've got a 2000 1.8tqm, engine code ATW. On the ATW and AEB 1.8t's there are two O2 sensors, one upstream of the cat and one down stream of the cat. They analyze the amount of unburnt fuel in your exhaust and subsequently adjust the fule mixture accordingly. Less air, the mixture is rich, too much air, running lean. Running rich, your MPG plummets, running lean, you can lose performance. The perfect mixutre for gasoline is about 14:7:1. Replace both of them, that cleared up that error code on mine. The upstream is easy to get to, the downstream on the other hand, not so easy. The parts are about $130ish a piece. I'm not sure on the labor, I did mine myself. Make sure wherever yu get them from you specify what engine code you have!!! Otherwise they'll likely send you an O2 sensor for a Fiat, or something.... PM me you engine code, I'll get you the part numbers you need,
Doose
Old Mar 19, 2005 | 02:11 AM
rnbguy's Avatar
hi,
thanx heaps for that reply, however ive taken it to a mechanic he said the rich fuel mixture is happening before the cat system as its giving my spark plugs a different color and other noticable facts... do u think its more then likely the o2 sensor? nothing else? ive tried simple stuff like changing air filter
Old Mar 19, 2005 | 02:14 AM
BFlan's Avatar
the failed o2 sensors will make your whole system run rich, not just after the cats.
Old Mar 19, 2005 | 02:16 AM
rnbguy's Avatar
ah okay i had a feeling it was the o2 sensor, okay i tried to find "Group 032" in engine, using vag-com but that returned error, wanted to know the mixture... could it be the MAF?
or that code defenitly means o2?
Old Mar 19, 2005 | 04:20 AM
rnbguy's Avatar
just reading other posts on this forum, and im thinking it might be a vacumm hose? or MAF or o2 sensor?
what would u guys bet on?
Old Mar 19, 2005 | 04:25 AM
rnbguy's Avatar
assuming that this section of the fault code is giving away the o2 sensor is gone:
P0134 - 35-00 - -
is there anyway to know which of the 2 is gone? if there are two o2 sensors on the n/a audi a4... i dont wanna replace both
Old Mar 19, 2005 | 11:59 AM
CRAZYHAWK's Avatar
It is the upstream one. The downstream O2 sensor is used to determine that the catalyst is working.
