Help Needed
Old Jan 5, 2005 | 01:05 AM
sayho's Avatar
Default Help Needed
My car won't start this morning, so i brought it to Les Schwab to change a new battery.
Here is the problem:
1) The battery they gave me is different in physical size, it is smaller than the old one, they insist it has no differences other than the size
2) Can someone give me the specs to the original Audi 2000 A4 1.8T battery? So that I can compare to the one they gave me.
Thanks alot guys!
Say
Old Jan 5, 2005 | 01:09 AM
Jestnomen's Avatar
6th Gear
Default RE: Help Needed
What brand battery did they stick in there? I wouln't worry about it too much.
Old Jan 5, 2005 | 01:14 AM
sayho's Avatar
It is Les Schwab 47 XT Xtreme Power Battery, the right size should be Les Sschwab 48, but they do not have it, and say 47 is the same.
When i turn the key to the first position, before ignition, the battery meter shows 12 volts, when i started the engine, it shows around 14-15 volts. Does this sound right?
Thanks.
Old Jan 5, 2005 | 02:50 AM
Jestnomen's Avatar
6th Gear
Yep, that means your alternator is charging the battery properly. If you read less than 12Volts when the engine is on you have an alternator problem.
Old Jan 5, 2005 | 12:37 PM
CRAZYHAWK's Avatar
You are correct, 48 is the right battery. Check the Cold Cranking Amperes.
Old Jan 6, 2005 | 04:28 AM
sayho's Avatar
The cold cranking amp is about 750, is that # right for Audi A4?
Old Jan 6, 2005 | 11:03 AM
CRAZYHAWK's Avatar
750 CCA is good. The 48 battery has a center vent.
desertsnake1991
Aug 28, 2012 11:07 AM
thenjd
Jan 23, 2008 04:00 AM
raffysaudi
Feb 5, 2007 06:44 PM
GregaXX
Feb 3, 2007 09:37 PM
poloblue22
Aug 3, 2005 11:10 PM
