Help Please - Temperature
temperature gauge behaves erratically ?????
when i turn on the A/C after few minutes of driving,it drops down to a quarter and then it goes back to middle and so on
again it only does it when the A/C is turned ON
i replaced the Temp Sensor(parts from audi)
I had the thermostat, water pump etc. replaced,[:@](could it cause the problem if the parts are not from audi)
Thanks
Thanks
RE: Help Please - Temperature
What you need to do is make sure what the gauge is telling you is actually true, so you can either feel the hoses going into and from the thermostat and see if they feel the same, cool or hot.
Or the best route to go is find someone with a temp gun and measure the heat of the hoses.
LOL, ok what do you wan't me to tell you? You gotta do something, just feel the damn hoses when the gauge is fluxuating and see if the temp of the hose is getting hot and cold as well, i don't know what else to tell you.
