how do i change power steering fluid?
Old Mar 11, 2007 | 04:52 AM
ryanisaninja's Avatar
Default how do i change power steering fluid?
as you can probably tell, im not very knowledgable with these cars. i tried searching and looking under the hood and for the life of me, i cannot find where im suppose to drain and refill the power steering fluid. im getting some loud screeching noises when i turn the wheel and i think im running low. can anyone help me out with this?
ps: sorry for the ignorance. im just trying to get this fixed.
Old Mar 11, 2007 | 06:10 AM
BadLuckAudi's Avatar
Default RE: how do i change power steering fluid?
try just adding fluid first if you really wana change it you will need a vac pump to suck it out
Old Mar 11, 2007 | 05:35 PM
yeah, ill try to just add it first but i need to know where it is located to refill it. i should probably know this i know but i dont have any manuals.
Old Mar 11, 2007 | 05:41 PM
A4nicator's Avatar
the cover said brake fluid on it.
Old Mar 11, 2007 | 06:43 PM
david9999's Avatar
Driver's side near the front grill with the green top.
However, before you ruin your steering rack, you cannot put "off the shelf" Power steering fluid, or automatic transmission fluid.
You need to buy Pentosin 11S synthetic fluid, or go to VW and get OEM.
If your power steering fluid is low, find the leak.
When I change mine, I just use a small turkey baster and change what is in the reservoir every 15K miles.
jeeplover38
Oct 31, 2010 01:34 PM
ramiajjuri
Nov 2, 2007 08:55 AM
cipherchris
Apr 1, 2007 02:21 PM
thrax982
Mar 31, 2005 10:15 PM
