How do you tighten E-brake
Old Nov 28, 2007 | 06:29 PM
Notahondaowner's Avatar
Default How do you tighten E-brake
Ok finally changed all 4 brake pads today, I think next time ill do one set then save the others for another day. Anyhow 3 beers 2 hours later finally learned how to do audi brakes. Still having the same problem i had with my rear brakes, seems like my e-brake is very loose. I pull it all the way up and my car still moves in reverse, it is engaging because it is slowing the car, but i know it needs to be tightened. Searched AF and the net for how to tighten the e brake cable with no luck.
Old Nov 28, 2007 | 06:45 PM
RaFa's Avatar
Default RE: How do you tighten E-brake
did u leek the brakes?
Old Nov 28, 2007 | 06:47 PM
Pumped the pedals as required, the fluid over flowed a bit while compressing all the pistons, but the fluid is at the proper level, fronts are workin great.
auditech79's Avatar
Follow the e brake cable in the back of the car to where it comes to a sleeve, loosen the lock nut and turn the sleeve a couple of turns, do the same to the other sleeve so they are even. Continue turning the sleeves until you get your desired tension.
Old Nov 28, 2007 | 06:52 PM
ORIGINAL: auditech79
<3 you
thanks
Laura JS
May 3, 2011 01:23 AM
pbrules10
Dec 25, 2010 12:39 PM
Inibalir
Apr 29, 2008 05:41 PM
generik777
Apr 4, 2007 08:38 AM
ckandes1
Dec 5, 2006 10:22 PM
