AudiForums.com
-   Audi A4 (https://www.audiforums.com/forum/audi-a4-8/)
-   -   i dont like it when my car goes bump bump bump.. (https://www.audiforums.com/forum/audi-a4-8/i-dont-like-when-my-car-goes-bump-bump-bump-19661/)
rnbguy Nov 13, 2005 09:08 AM
Hey people how r we today... just a quick question and i know this is hard to describe on the internet but i like trying this place out before i take my car to get checked out ... just so i have a rough idea...
when i drive i notice at certain times i hear my car make a bumping noise its comming from under the car toward middle/rear... it doeesnt happen when im idle, but it happens when i turn but more when i brake or when the car changes gears, what do u guy think it could be?
its like a "DUMPE" noise if that makes sense lol
onepoint8tee Nov 13, 2005 11:46 AM
RE: i dont like it when my car goes bump bump bump..
Yeah that makes just about no sense at all to me. Engine mount(s)? Bushings? When the cars weight shift around like when your turning or braking that could very possiblly be a bushing problem/sway bar links/????????? Good luck on that.
fcanozo Nov 13, 2005 11:55 AM
the exhaust also?
ackjazz Nov 13, 2005 02:58 PM
First thing I would check are the bolts for the rear sway bar. Sounds like they are loose or gone on one side only. Do you feel any difference in handling in the turns from when you first got it?
It could be the sway bar bushings too. If so, that's really simple to fix. While you're at it, replace the OEM sway bar with an S4 OEM sway bar...makes the rear end stiffer and more neutral through corners, allowing you to turn the car more effeciently and it won't feel like it "plows" in the corners.
Motor mounts would "bumpe" when shifting or accelerating hard...straight line stuff.
Could also be the spring perches in the rear. If the sound were coming from the front, it could be any number if front end bushings or parts.
rnbguy Nov 14, 2005 10:43 AM
thanx for the reply guys, ill get a mechanic to look at it after i finish my uni exams, i was hoping i could look at it myself, any way of jumping under the car and noticing nething? or should i just get a pro to look at it, i usually do engine work and interior work neva done body work, btw ive had the engine mounts dont recently so im hoping that elimenates that, and the car handles exactly the same as before...
ackjazz Nov 14, 2005 07:32 PM
ORIGINAL: rnbguy
A klunk could still be the sway bar bolts. They are easy to see. Crawl under the car from the back. Look up to the right and left and see where the sway bar (about 19mm thick - black) that connects the two sides of the rear suspension is attached. The poly bushings are about 4 ft apart in plain sight with a metal bushing harness held by two bolts each. If one bolt is out or loose, it could be your klunk.
