I messed up
Old Jan 22, 2008 | 03:30 PM
pimphell's Avatar
Default I messed up
I took my black a4 and tried to test pipe it. I got the cat off with little problem. Put a pipe in its place and took it for a drive. Now my previous knowledge of test piping, is that it always is an improvement. Not in this case. The turbo doesn't spool up as fast as it used to. That sucks, bad. So i guess that i'm writing this in lure that no one else tries to do the same thing on this car. I'm going to go to a muffler shop to have the cat welded back on this friday. I guess lesson learned, don't change the stock exaust at all, it is very good design to begin with. It does sound deeper without it
Old Jan 22, 2008 | 03:34 PM
Rhinop21's Avatar
Default RE: I messed up
???? How would reducing back pressure result in less turbo spool?
viper9821's Avatar
Ummm that doesn't sound right at all. I'd be worried something else isn't right.
Old Jan 22, 2008 | 03:35 PM
Jeff's Avatar
Zombie Defense Force
well you did something wrong then. the stock exhaust sucks. tp should help out a lot.
Old Jan 22, 2008 | 03:38 PM
pimphell's Avatar
i have no clue as to why it would result in turbo lag
pimphell's Avatar
i dont know how i could have done somthing wrong??? you cut and replace, pretty simple
Old Jan 22, 2008 | 03:49 PM
Jeff's Avatar
umm what did you cut? it should be unbolt and replace
Old Jan 22, 2008 | 03:54 PM
Rhinop21's Avatar
^Yea did you cut something? Its unbolt and bolt on.
Old Jan 22, 2008 | 03:58 PM
feerocknok's Avatar
troll.
Old Jan 22, 2008 | 04:10 PM
Kyle09's Avatar
Did you cut out your resonator thinking it was the catalytic converter? The catalytic converter is bolted right up to your turbo/exhaust manifold..
