i need help fitting a dump valve blow off valve bov please please please
hi there everyone
i have just bought a baileys dump valve and fitting kit.. and they send me NO instructions so i am really stuck.. so if anyone can please help and some pics of fitted ones would be a help too thanks everyone[:@][:@][:@][:@][:@] |
RE: i need help fitting a dump valve blow off valve bov please please please
do you got the right flange?? whats the "fitting" kit?? is it by any chance a hose that blows the air back into the intake, if not than your car is gonna run like crap...
its a baileys dv26 dump valve with a fk96 fitting kit......
and its a blow off valve,....... |
just be prepared to have some trouble with your catalytic converter later in your cars life, and also be prepared to have some runnig problems with your car... but if you really wanted the bov... to each his own... im not gona knock you for it... check with the company you purchased it from... also does it mount to a flange or does it mount though the stock dv location?
can you post a pic with all the parts you have????
E |
ok, do you know where the stock dv is???
the valve you got, is the kit so it will fit an audi?? is there a C clamp?? you have to get the fit kit on the bov then find the stock dv.....yes you have to pull the belly pan then remove the stock dv plug the return line(the one going back to the intake) install the bov and run new vacume hose from the intake to the bov(follow the old line) that should do it, sounds simpler then it is... if you have more questions....ask E |
do you have any pics i am just not sure where the pipe goes that come out of the new valve
sorry i mean the one that come out the top of the valve....
and what pipes i need to block off... thanks for the help mate |
these are the parts i have.....
hold tight the pic's are on the way, they were too big
| All times are GMT -4. The time now is 09:51 PM. |
